Need help with CUSTOM GROUND POINTS..
Old Sep 2, 2007 | 12:15 AM
FishyMan's Avatar
I am wanting to do some custom ground wires. I have done a free search but didn't come up with anything.
I am basically using 4 GAUGE wires. I would like to know how to ground, or wire it. Can I just replace the stock points, if so where?
Any input appreciated.
Old Sep 2, 2007 | 05:23 AM
renagade281's Avatar
i always use the bolts that hold my seats to the car (front seats) because i know thats one of the best grounds in the car
Old Sep 2, 2007 | 11:15 AM
99grnmaxgxe's Avatar
http://www.activetuning.com/products...stallation.php
He wants engine grounds, not one for an amp.
Old Sep 2, 2007 | 11:20 AM
joepino's Avatar
just use the stock grounds. they worked fine from the factory. using better wire helps out with your electronics and sensors so your car runs better
Old Sep 2, 2007 | 12:03 PM
Max Noob's Avatar
main engine ground front of the engine block near the radiator onthe battery side.
main chassic ground is next to battery between the battry cage and the air box.
Old Sep 3, 2007 | 08:12 PM
GTRMaX's Avatar
You can use the factory grounds they work well just make sure you sand off any rust or if your going to use custom ground points make sure you sand off the paint down to the bare metal.
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
carid
Sep 17, 2015 05:00 AM
