clear tail help
Old Jul 22, 2001 | 05:52 AM
j_bryan's Avatar
Hey I replaced my clear tails a few days ago. When I removed the stock tails, there was a black, thick compound (some kind of sealant i think) around a portion of the tail.
Do I need to reapply this to the new tails?
When I washed my car, i sprayed a lot of water around the tail area to check for leaks and a lil water seeped into the trunk. Has anyone had this problem? Suggestion on where to get this adhesive/sealant??
Old Jul 22, 2001 | 06:04 AM
NickStam's Avatar
Did you push the tails in all the way and screw them in really good? It should be very difficult to get water past them. Just got to your local auto parts store and get some silicone sealant. That should work.
Old Jul 22, 2001 | 09:19 AM
j_bryan's Avatar
Yeah, screwed them in tight. I didn't find any water on the right side, just a little bit on the left. I'll get the silicon. Thanks.
Old Oct 11, 2001 | 12:35 PM
dashingMax's Avatar
Did that silicone sealant work for you or did it get even more screwed up?
Old Oct 11, 2001 | 01:48 PM
j_bryan's Avatar
i never got the silicon, leaking seems to be minimal to non existent now so i'm not going to bother with it. hope this helps
Old Oct 11, 2001 | 02:01 PM
dashingMax's Avatar
It must've sealed itself over time. Yes, it helps...
Old Oct 11, 2001 | 04:15 PM
ny96max's Avatar
That black stuff is called butol-rubber. You can buy more if necessary at any local shop that installs car windshield/glass.
shouldnt be more than $5 a roll.
You definitly should re-apply the butol rubber, thats what pretty much keeps water out of your trunk!
Old Oct 11, 2001 | 09:33 PM
dashingMax's Avatar
I got butol stuff all over my hands...
I tried to do the mod tonight. I screwed up!! I did everything right up to using the heat gun and removing the lens. I cracked the lens. To make things worse, I must've pulled really hard on the bulb wires and my side marker bulb is dead. The bulb itself looks okay, it looks like the wiring got pulled too hard. The sure way to find out will be to use a Voltmeter...
OUCH!!
Now I am thinking, should I spend $200 and get the clears from CustomMaxima.com or should I buy the Stillen front lip for $175 and get it installed totalling around $250... I dunno...
Does anyone know how much to paint & install the front lip on 99 Max?
Old Oct 12, 2001 | 05:35 AM
njmaxseltd's Avatar
J_bryan -- That is one AWSOME car in your sig man.
Old Oct 12, 2001 | 06:22 AM
j_bryan's Avatar
yeah, i wish i could tell you that it's mine, but i can't and it isn't!!
maybe one day though, but it's over $50K new! so for now, it's moddin' tha max!
this is actually the european model, i haven't seen any amg 32's on the road to see if the american version looks as good.
maybe i should test drive one and take it to a track!! lol!! would love to know what it could do in the 1/4..
Old Oct 12, 2001 | 07:20 AM
thrustinj's Avatar
Actually the rubber molding is what keeps water out of your trunk.
Old Oct 12, 2001 | 08:18 AM
ny96max's Avatar
njmaxseltd: your car looks sweet with the flaps painted to match, all you need now is the Stillen front lip and your set.
Old Oct 12, 2001 | 08:29 AM
dashingMax's Avatar
How much did that front lip installation cost you? That is paint and install...
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
