Help another problem with my brothers car
Old Sep 7, 2007 | 07:35 PM
WhiteA32's Avatar
Ok First the car just kept shutting off by its self
So the dealer replaced the Thermostat, and the radiator (or flushed it)
Now my brother drove the car to school and home with out any problems. After letting it sit for about 2 hours. We can't even start the car. It just cranks and cranks. So I tapped the gas a lil and it starts up. But has a really low idle around 510 ish, I am assuming that this is why the whole engine is shaking and making the car shake. After that i looked back at the tailpipe and saw white smoke coming outta it.
And thats also when the CEL started flashing.
Never ever seen a flashing CEL. I have one on my 98 and its solid (o2 sensor)
Any ideas?
Old Sep 7, 2007 | 07:38 PM
f550maranello2's Avatar
check for codes..... also does it have any black smoke comming out of the exhaust? if so look at the fpr
Old Sep 7, 2007 | 07:46 PM
WhiteA32's Avatar
it was white smoke....
Old Sep 7, 2007 | 07:50 PM
white smoke? check the oil see if there is any coolant there..
Old Sep 7, 2007 | 07:57 PM
99BlackMaxMS's Avatar
You could be misfiring causing the CEL to flash. White smoke does mean that you are burning coolant tho...
Old Sep 7, 2007 | 08:13 PM
WhiteA32's Avatar
OK and since the 99s have problems with the coils that would cause all this too happen?
So we have to replace the coil pack
Is it bad to have coolant in the oil. I would assume so but its not like the engine gernaded right?
Old Sep 7, 2007 | 08:29 PM
KRRZ350's Avatar
Wow what's up with all these blown headgasket threads?
Do you have coolant in the oil or vice versa? yes that's bad, it's horrible, engine drop & swap time.
Old Sep 7, 2007 | 08:56 PM
WhiteA32's Avatar
Wow, well we just bought this car like 1 week ago. I hope the private dealer that we bought it from covers it....
Old Sep 8, 2007 | 09:43 AM
WhiteA32's Avatar
OK I took some pictures.
The one on the right is when I took the dipstick out and just whipped it. The one on the left I inserted back and took out again and whipped.
After I did that I saw something neon green in the oil cap. So I whipped that and this is what I saw...
So I am assuming that there is antifreeze in the oil.
Old Sep 8, 2007 | 09:49 AM
yea it is .. new motor time....
also the oil will look like chocolate milk.. if it does then its a sure sign...
Old Sep 8, 2007 | 07:05 PM
Snypa's Avatar
now how the hell did antifreeze get in there?Damn man.take that back to them definately.......1 week.!!
Old Sep 8, 2007 | 08:31 PM
maxima985spd
eeeeeeeeeeeeekkk good luck bro let us know whats up
Old Sep 8, 2007 | 08:53 PM
WhiteA32's Avatar
Well that dealer towed the car back. We will find out on monday whats going to happen...
Old Sep 8, 2007 | 10:47 PM
KRRZ350's Avatar
Do they have a garage or do they sublet there work? You should go there and be like.......... "listen buddy, the block seal you put in didn't work, give me the car for $1,500 less than what I payed and we'll all be happy"
Old Sep 9, 2007 | 05:59 PM
^^ Hahah free 3.5 swap basically
Old Sep 10, 2007 | 12:17 PM
WhiteA32's Avatar
OK
You were right. Toodles to the headgasket.
Right now the guy is changing out the motor on the car. With another 3.0.
Anything I should check on the car to make sure the install went well when we get the car back?
Old Sep 10, 2007 | 12:39 PM
maxima985spd
WOW thats bad luck
Old Sep 13, 2007 | 07:29 PM
bearded's Avatar
wow, glad the dealer took responsibility. You could have been royally screwed.
Old Sep 13, 2007 | 11:09 PM
maxpeed96plat.'s Avatar
Originally Posted by WhiteA32
OK
what's the milage on the used motor? check compression, oil leaks etc.
Old Sep 14, 2007 | 07:28 AM
WhiteA32's Avatar
The dealer said that it was a 90k motor
Old Sep 14, 2007 | 10:24 AM
Nealoc187's Avatar
SLOW
wouldn't have been THAT bad... I replaced a motor in a 4th gen for $400 all inclusive (fluids, motor, etc). but yeah it's great the dealer did it for him, alot less headache.
Old Sep 14, 2007 | 01:18 PM
WhiteA32's Avatar
OK were getting the car back today I think, what should I look for or double check to know that the motor is reliable....???
Old Sep 14, 2007 | 07:05 PM
WhiteA32's Avatar
OK I got the car back. There is a check engine light for Output Speed Sensor P0720....
The stickies are all messed up and are linking things to the wrong thing.... any idea?
Old Sep 14, 2007 | 11:34 PM
^^check the connection on the speed sensor (on transaxle) might be loose, is ur speedo working? and the milage doesn't sound bad.
Old Sep 15, 2007 | 05:20 AM
WhiteA32's Avatar
Yea the Speedo works just fine.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
dauntlessmax
Aug 5, 2015 10:29 AM
yat70458
Aug 3, 2015 01:16 PM
