OEM ALARM NEEDed HELP
Old Jul 24, 2001 | 08:13 PM
MigthyMax's Avatar
the alarm never engage... the security ligs flashes when the car is off... and it turns off when the key is in the engi. but other than that it does not engage.. the keyless entry works fine...
Old Jul 24, 2001 | 10:29 PM
justmax's Avatar
well...
How do you know the alarm doesn't engage? Does the little red dash light stay solid for 30 seconds then start blinking? If you roll down the passenger window, get out, hit the "arm" button, and then reach inside and open the door, does the horn honk?
Justin
Old Jul 24, 2001 | 10:46 PM
blee89xj's Avatar
what exactly does the factory alarm do anyways, they don't go into details about the alarm in the manual. I haven't even been able to figure out how to set it off.
Old Jul 24, 2001 | 11:29 PM
justmax's Avatar
umm...
Refer to my previous post.
Old Jul 24, 2001 | 11:59 PM
MigthyMax's Avatar
Re: umm...
Nah it does not go off at all.... asoon as you take the key off the eng. it flashes and it keeps flashing I have left the windows half way down, and lock the door and then try to open it like that and it does not go off.. I have waited more then 2 minutes before I do it... any ideas why?
-JL-
Old Jul 25, 2001 | 08:37 AM
justmax's Avatar
Re: Re: umm...
-JL-
Sounds like it may be time for an aftermarket alarm. The factory alarm doesn't have a shock sensor, and it sounds like yours isn't working at all, so it's a good time to upgrade! Just be glad you found this out instead of some criminal.
Justin
Old Jul 25, 2001 | 09:14 AM
MigthyMax's Avatar
Re: Re: Re: umm...
Justin
If I change the alarm.... do I lose the keyless entry...
-JL-
Old Jul 25, 2001 | 11:05 AM
Kevlo911's Avatar
Kevlo for President
i thought it said in the owners manual that the alarm does not work if the windows are down. TEST ALARM: get in the car. make sure the windows are up. hold the key in ur hand, push the lock button. wait 30 sec until the security light starts to flash and then pull on the lock(the thingy above the door handle). the alarm should go off
Old Jul 25, 2001 | 11:18 AM
Speebs's Avatar
I aim to misbehave.
30 seconds?
My security light starts flashing as soon as I turn off the car.. is that wrong? I will test the alarm to make sure it's working tonight!
Old Jul 25, 2001 | 11:20 AM
Kevlo911's Avatar
Kevlo for President
Re: 30 seconds?
mine stays bright red for 30sec then starts to flash when i push the lock button
Old Jul 25, 2001 | 10:02 PM
MigthyMax's Avatar
Nah my alarm doesnt work... even if I stay in the car and lock it with all the windows up and... wait more then 30 sec... it does not off.. the only way I can sett it off is by using the panic button... on the contoll...
Old Jul 26, 2001 | 01:20 AM
jiaxima96's Avatar
Re: 30 seconds?
Do you mean you turn off the car and open the door? My 96 GXE does this: if either one door, or the hood, or the trunk is open, the LED will blink with a faster speed than when the alarm is set (30 seconds after everything is locked).
Old Jul 26, 2001 | 06:41 AM
Speebs's Avatar
I aim to misbehave.
nope...
no.. I mean as soon as the engine is off the security light comes on. I know I can set off the alarm by using the panic button; I haven't gotten a chance to try the door opening thing yet (actually it's more like I keep forgetting). Thx.
Old Jul 26, 2001 | 04:25 PM
Speebs's Avatar
I aim to misbehave.
Mine's not working either :(
Man.. all the buttons on the key fob work, the security light flashes (see above), though not necessarily the right way, but I can't manage to set the alarm off. Looks like I'm having the exact same problem as MightyMax. Any suggestions before I bring it to the dealer?
Old Jul 26, 2001 | 06:27 PM
maxium nrg's Avatar
while on the subject of the factory alarm...Is there any way to add a shock sensor to the factory alarm? i found out it'd cost a grip to get all the features the factory alarm already has plus shock sensors.
Old Jul 26, 2001 | 07:04 PM
Vyrus's Avatar
5th Generation Alarm...
Just wondering if the 5th gen alarm is any better than ours? Does it have a shock sensor? Thanks.
Old Jul 26, 2001 | 07:25 PM
MigthyMax's Avatar
I Have checked the Alarm every singel way posible.... and it just doesnt work.. I will check the relays and fuses to see if there is something wrong......
Old Aug 5, 2001 | 03:44 PM
MigthyMax's Avatar
Did you guys ever get you alarm check or fix... I got my fix this weekend and it work *****in.. well as *****in as the OEM Alarm would work....
Old Aug 11, 2002 | 07:19 PM
Speebs's Avatar
I aim to misbehave.
What was wrong with it?
Old Aug 12, 2002 | 03:21 AM
greenmax's Avatar
My brother had the same prob he took it to the dealer and it was a relay for the alarm.I would say check the relays also try disconnecting the battery for 5 min then connect it and see if it works.
vingodine
45
May 21, 2016 12:46 PM
smplyamzng
Dec 13, 2015 01:19 PM
03VQMAX
Sep 25, 2015 04:19 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
TonyJr
Aug 20, 2015 12:14 AM
