wheel studs
I have a question. last week one of my wheel studs (what the wheel goes onto and you put the lug nuts on) broke from it somehow rusting onto the lug and then fusing together so I had to just over torque it and break it off. I was wondering if anybody knows how to change the wheel studs in the front and in the back. I went to the dealership and bought new studs already and was gonna have them do it but the labor cost was just too outrageous. thanx
You can buy these manuals at any large bookstore or any auto parts store. You may find them on the shelf at your local public library.
The replacement stud and nut are inexpensive, so you will save a lot by doing this job yourself. Good luck!
would these manuals be on the internet? I don't want to buy a whole manual just to check on this and i'm too lazy to go to library...if it can be found on net, it would be much easier for me...who are the author's again? and what's the name of these manuals?
have to agree that manual (Chiltons or Haynes) is worth every penny!
It's a piece of cake to replace wheel studs. I snapped one on the front. I actually did it without the manual. I just looked at the manual to compare my method and Haynes' - Point 4 was the only addition to Haynes' steps.
1. use hammer/drift to knock the old stud out.
2. remove caliper
3. remove rotor
4. Rotate wheel to be replaced to caliper position
5. insert wheel stud
6. Replace rotor
7. replace caliper
8. Find oversize nut as a spacer and tighten lug nut to pull the stud into position.
2. remove caliper
3. remove rotor
6. Replace rotor
7. replace caliper
manual
if you still haven't done it, i can scan the pages for you and email them and you can print them out, if you want to let me know
aol im = antirohdeclan
or my email is thebrad32@hotmail.com
Andy29
Sep 29, 2015 05:32 AM
