Decisions...
First off, has anyone ever heard of a suspension company called "Progressive Group"? Some guy at a local shop recommended them to me since he said Sprint springs would create a negative camber on my wheels because they are too low (PGs are 1.7/1.5 as opposed to the 2.0/2.0 of the Sprints).
Now.. Im debating which set of mods I should do first. I could do the springs and struts for about $1200 CDN. Or I could probably get a decent muffler, intake, Strut tower brace, and rear sway bar for about the same. I dont have much more than $1200 to spend right now :P
Any input would be greatly appreciated.
Adam
Adam
Adam
Adam
just trying to help
Why not just buy the Sprints and get a $25 camber correction kit. Any spring will create negative camber, it's all a matter of how much. And that .25" difference isn't going to be much difference camber wise.
Adam
Adam
For regular camber bolts that adjust your camber up to +/- 1 degree, it's like $25-$35 or so. There are a bunch of brands. For camber plates which give you much more adjustment, it's like $300. Don't know where he got that $500 figure from. To know if they did it correctly, just get them to align the car. If the car is aligned properly and within specs, you should be fine.
The guy that I talked to said the camber correction kit was like $500. Is there a specific brand you recommend? Also once its installed, how would I know the shop set it correctly?
