Quantity and Ratio for coolant flush
Aug 2, 2001 | 12:10 PM
Does anyone know how many gallons the cooling system will hold full?
Also what is the correct coolant to water ratio for a 95 max?
Thanks for your help...
Aug 2, 2001 | 12:27 PM
Coolant Info
The ratio is 50% I just did mine recently. Actually I'm still doing it, too. I've flushed it once and I'll do it a second time sometime later this week. I don't remember the capacity off-hand. I just kept filling up until it was full.
Also, did you take the 2 plugs off of the engine block?? That's the only way to completely drop all the old fluid. I didn't. Those plugs are **extremely** hard to get to, tucked behind the exhaust manifold on each side.I didn't bother. I decided to flush several times to get most of the old stuff out.
DW
Aug 2, 2001 | 12:30 PM
does anyone know the optimal ratio for use with Redline's Water Wetter?
