DBM ---> Brake light & Engine coolant temp sensor
Stopped at a light, I slammed on the gas hard and the brake light came on then off. I just thought the fluid was low. The next morning, cool outside, the light is on constant. In the afternoon when it's hot outside it isn't on at all. I checked the level to be about an 1/8" above the "min" line. Should I add more or is this not what could be triggering the light? I haven't noticed any problems braking, and I also haven't notice signs of brake fluid leaking. Any suggestions?
Also, I posted a thread earlier about the Engine Coolant Temp Sensor, I ordered the part and was planning on flushing the coolant, replacing sensor, and that would be that. I just recently noticed that the "check engine" light turned off without me resetting it. That doesn't make any sense to me. Could you give me a brief idea how the car does it's own diagnostics. Why would it be on constant for a week then suddenly turn off without the problem being rectified??
Sorry so long....
Thanks for your help...
Sorry so long....
Originally posted by MadMax95
Stopped at a light, I slammed on the gas hard and the brake light came on then off. I just thought the fluid was low. The next morning, cool outside, the light is on constant. In the afternoon when it's hot outside it isn't on at all. I checked the level to be about an 1/8" above the "min" line. Should I add more or is this not what could be triggering the light? I haven't noticed any problems braking, and I also haven't notice signs of brake fluid leaking. Any suggestions? ...
- handbrake is on
- brake master cylinder reservoir fluid level is low
Most likely your light turned on because of fluid level. Add brake fluid to the Max line.
... Also, I posted a thread earlier about the Engine Coolant Temp Sensor, I ordered the part and was planning on flushing the coolant, replacing sensor, and that would be that. I just recently noticed that the "check engine" light turned off without me resetting it. That doesn't make any sense to me. Could you give me a brief idea how the car does it's own diagnostics. Why would it be on constant for a week then suddenly turn off without the problem being rectified??
The ECM logic can decide that a previously recognized problem no longer exists and it will extinguish the Malfunction Indicator Lamp without a manual reset. Perhaps the most common example is the loose fuel filler cap. A loose cap causes the fuel integrity test to check "bad". Tighten up that loose cap and the MIL will turn off after a certain number of trips in which the fuel integrity test checked "good". I don't know the number of "good" trips required to turn off the MIL, but it is something like 20.
A tip-off
... I checked the level to be about an 1/8" above the "min" line. ...
When your fluid level is low that may be a tip-off that ...
- your brake pads are worn and will soon require replacement
- there is a hydraulic leak somewhere in the system
vingodine
45
May 21, 2016 12:46 PM
JMag90
Aug 25, 2015 09:17 AM
