Attn: Daniel B. Martin-clicking noise under hood
Daniel B. or anyone who knows how to fix my problem. The other day I was looking under my hood and I heard a ticking sound. My keys were in the ignition but the car was not running.(the engine was cold) Does anyone have any idea what this might be? Thanks for your help in advance!
-MDM
-MDM
WAY to vague. Was it the only one time or did it do it continuously? Was it from any particculaer part of the engine. What were you doing? Does the car run okay? You need to fill in the holes.
-MDM
-MDM
When you have more specific information about the source of this suspicious sound post it on this thread.
Will do...
Daniel, I'll go buy some hose tomorrow and try to pinpoint the noise. I checked on it earlier (engine cool for 5 hours), whenever I put the key in the ignition and turn it to acc, a "ticking" sound is heard somewhere near the center of the car behind the engine block. I'll be more specific tomorrow.
-MDM
-MDM
Originally posted by medicsonic
Are you sure it isn't the fuel pump?
- The fuel pump makes a whirring sound, not a ticking sound.
- The fuel pump is located inside the fuel tank. The sound it makes is more noticeable at the rear of the car than under the hood.
- The fuel pump does not run with the ignition off. With the ignition on but the engine off the fuel pump runs about four seconds and turns off.
Originally posted by Daniel B. Martin
This sound is unlikely to be the fuel pump becuase ...
- - The fuel pump does not run with the ignition off. With the ignition on but the engine off the fuel pump runs about four seconds and turns off.
I'm just throwing possiblities out. Hell, it could be anything, from noisy pre-cats to a loose electircal connection.
... Hell, it could be anything ...
Not too sure...
Here goes nothing....
I did what you said to do DBM with the hose. I'm not too sure where it's coming from but I pinpointed it down to 2 locations.(yellow circles) The picture I'm using is not of my hood, but it's similar. I don't have the K&N cone.
Not too sure...
So what do you assume it may be?
Re: Not too sure...
The smaller oval looks like the Throttle Position Sensor. There is a good photo of the TPS in the Haynes repair manual, page 6-9.
I tried to recreate your Key On, Engine Off situation but did not hear any clicking under my hood.
You could pull the ASCD fuse temporarily. That's fuse #12, 7.5 amps, in the passenger cabin fuse block. Then listen for the clicking sound. If not heard, that would point toward the ASCD.
One component in the ASCD is an electric motor driven vacuum pump. This part is perfectly silent on my Maxima. However, on the Stanza I formerly owned this pump always made strange sounds as soon as the key was turned on. The ASCD always worked well, so I accepted the strange sounds as normal. Not desirable, but normal.
Unclejunebug
Apr 2, 2016 05:42 AM
