Bad Battery....
Old Aug 8, 2001 | 04:24 PM
Yellowbrother's Avatar
i had my battery check and autozone confirmed that it was a bad battery....i got the battery replaced....the guy who tested my battery said that my old battery was extremely drained of it's power.....he said that my alternator could be the cause....my question is:
1. what else other then the alternator could cause my battery to go bad?
2. how can i check if my alternator is good or bad?
3. can i check my alternator while it's on the car or does it have to be off the car?
thanx to anyone who attempts to help a brotha out....
Old Aug 8, 2001 | 04:58 PM
blizz20oma's Avatar
I'm so hood
Was the battery prematurely drained of its power, or was it new/newish?
As far as alternators go, I don't think there's any way to know of when your alternator is getting close to crapping out from inside the car. Basically, when mine went out in an older car, I got a warning earlier that day in that the battery light was coming on. The next time I went to leave, 10 min into the drive, I stalled at a light and lost functionality to any power accessories + the car. I asked a shop owner I know about it and he said you wouldn't notice gradual differences (ie, windows rolling up/down slower, stereo not drawing as much power, etc) with the alternator - that despite gradual wear on the alt itself, it still puts out power at an all or nothing rate.
Just going with what he told me (he's a friends dad, it was just a casual chat). Dunno what else could be draining your battery....lots of stereo/accessory use/overall power draw with the engine off?
Old Aug 8, 2001 | 06:34 PM
i do have an audio system....but i NEVER play my radio with the engine off so that is out of the question....
Old Aug 8, 2001 | 06:59 PM
Jon91SE's Avatar
Pusssseeeehhhh
Have your car check for shorts, there could be a short circut somewhere draining unecessary power, and as far as systems if your amp is underpowered you can kill a battery regardless if the car is on, this has happend to me, if when you sit at a stoplight blasting your music and your lights dim or the RPMs nudge down a little its drawing too much power get a bigger amp or a power capacator.....
Old Aug 9, 2001 | 03:42 PM
but my light doesn't dim tho....no indication of the amp being underpowered.....although i am still trying to hunt down the alternator whine....
Old Aug 9, 2001 | 04:14 PM
Daniel B. Martin's Avatar
It's not clear what is "bad" about your battery. If it is merely discharged, you should have it charged. If it is not capable of holding a charge, you must replace it.
These are some causes of battery failure.
- physical defect inside the battery (broken plates, broken inter-cell connectors, etc.)
- physical defect in the battery case (crack which allows electrolyte to escape)
- parasitic current drain (such as a trunk light which stays on even when the trunk is closed)
- age and frequent cycling (charge, discharge, charge, discharge ultimately kills a battery)
- lack of maintenance (owner failed to replenish electrolyte as needed)
The physical defects could arise from collision damage or driving the car without having the battery secured.
... 2. how can i check if my alternator is good or bad?
Some auto parts stores offer a no-cost charging system test. This is done with an electronic tester and takes only two minutes. Please have this test done. This test evaluates the entire charging system: battery, alternator, and regulator. The regulator is inside the alternator housing.
The charging system test mentioned above is done with the alternator in the car and the engine running.
... thanx to anyone who attempts to help a brotha out....
I'm troubled by this line. Maybe you mean well but it has the odor of racism. What would you make of a forum post which said "thanx to anyone who attempts to help a white guy"? "... help a Chinese?" "... help a Native American?" "... help a fascist hatemonger bigot?" ... etc.
Old Aug 9, 2001 | 07:52 PM
Originally posted by Daniel B. Martin It's not clear what is "bad" about your battery. If it is merely discharged, you should have it charged. If it is not capable of holding a charge, you must replace it.
autozone tried to charge the battery but they were unsuccessful of doing so....after they attempted to charge the battery they put the battery on this machine thingy and it ran a test....after bout 2 min it popped up a message saying "bad battery"...
i asked autozone and they say there is no such thing....
hmm...my nick is "yellowbrother" so i use the term "brotha"....also "brotha" as in we are all in a forum with a single interest....so i see all of us as "brothas" and "sistas".....no harm meant behind word...
Old Aug 9, 2001 | 08:01 PM
Free charging system test
... i asked autozone and they say there is no such thing....
Call around. Pep Boys. Advance Auto. Etc.
Old Aug 9, 2001 | 08:21 PM
Re: Free charging system test
will do.....is there a "politically correct" name for this machine?
Old Aug 9, 2001 | 08:28 PM
Re: Re: Free charging system test
Charging System Tester.
Old Aug 10, 2001 | 07:57 AM
SuDZ's Avatar
Lucky I guess
I was lucky enough that the previous owner ended up killing the battery with a radar detector a few days before i bought it. So he went ahead and bought a new battery for me for it. Nice way to save 70 bucks on a battery.
SuDZ
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
