Are 4th gen. stock REAR rotors vented?
Old Aug 9, 2001 | 01:16 PM
Maxwell's Avatar
I bought my 1998 SE used, and its rear rotors are not vented. I can't remember the last time I saw that. Is that stock?
After replacing the fronts, I still have a slight sensation of warped rotors, so I was planning on having the rears cut. But if they're garbage to begin with, I don't want to spend $20 having them cut when in 3 months I'll have to shell out for a new pair altogether.
Old Aug 9, 2001 | 01:29 PM
njmaxseltd's Avatar
Rear brakes on the car don't do as much braking as the fronts do. The split may be something like 30-70 70% being done by the front brakes. That makes for much less heat on the rears. So rears usually don't have to be vented or cooled.
If you still have a slight shake after new rotors were installed, my question is Did you have them cut on the car after your installation? That will insure the rotor will be true to the hub. If you did have them cut, then perhaps the rears do need some attention as well.
Hope that helps
Old Aug 9, 2001 | 01:42 PM
Daniel B. Martin's Avatar
Originally posted by Maxwell
I bought my 1998 SE used, and its rear rotors are not vented. ... Is that stock? ...
Yes.
Old Aug 9, 2001 | 04:51 PM
Dreizehn's Avatar
My rear rotors are solid... 95 GLE...
Old May 2, 2004 | 11:04 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
rear rotors are solid, fronts are vented
Old May 2, 2004 | 11:09 AM
happyricefob's Avatar
V^___^V
Hope that helps
http://www.motorvate.ca/video/video_...brake_test.wmv
hope that video helps too.
credit: mr. motorvate
Old May 2, 2004 | 07:32 PM
Dreizehn's Avatar
How and why did you resurect this thread? Start date: 08-09-2001....
Old May 4, 2004 | 07:26 AM
Brudaddy's Avatar
No need to get rotors cut...they warp too easily. They are really thin already, and when you cut them, they don't have enough integrity to withhold the heat from braking. Thus, they lose their shape.
Just get new ones for like $20 each at a local parts store.
Old May 4, 2004 | 07:31 AM
techie's Avatar
Yeah, three years would be a long time to be confused about a brake question.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
Maxilano
Aug 31, 2015 07:33 PM
