Uh Oh!!!! Car Problems
Old Aug 9, 2001 | 07:10 PM
Daddy Fat Sacks's Avatar
My check engine light came on a few days ago. Ijust finished checking it and it was 0505...no failure detected
When i started my car, i hear the normal chimes the car makes from the key being in the ignition, but this morning i heard a different higher pitched chime and it beep for a longer period of time than the normal chime, but the normal chime sounded also.
I hope my explanation is clear...
HELP
Old Aug 9, 2001 | 08:27 PM
Daniel B. Martin's Avatar
The Check Engine Light means one or more Diagnostic Trouble Codes were stored. When you did a DTC readout there were no Codes. Perhaps you inadvertently reset the Engine Control Module in attempting to do the readout. Don't be embarassed, this has happened to lots of people. When the CEL comes back repeat the readout process.
Old Aug 10, 2001 | 04:18 PM
thanks, the check engine light isnt on so that's what happened...do you know anything about the abnormal beeping noise without the ecu code?
Old Aug 10, 2001 | 04:24 PM
... do you know anything about the abnormal beeping noise without the ecu code?
No.
Sonic's Avatar
Mine does that every once in a while, but no drivability problems. Happened twice so far.
Old Aug 12, 2001 | 08:51 AM
i just noticed that my temp is high also...the code i got is 0704...which is the temp sensor i think
Old Aug 12, 2001 | 09:02 AM
Read the Sticky
Information pertaining to Diagnostic Trouble Code 0704 may be found in the Sticky ECU Diagnostic Trouble Codes.
The Engine Coolant Temperature Sensor has nothing to do with the dashboard temperature gauge reading.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Samedi
Aug 13, 2015 04:05 PM
erniel
Aug 8, 2015 09:32 AM
yat70458
Aug 3, 2015 01:16 PM
