HELP!!! cruise control and tachometer not working
i have a 95 max se, and the criuse control does not work, when a press the switch on the dash the light does not even come on. the fuse is good, so i don't no where else to check. however, i feel that maybe my tachometer problems may be related to the cruise control problems. when i drive the car the rpm needle stops at about 2-2500 rpms and just idles there will the engine continues to spin faster. its like the needle kind of bounces at around the 2-2500 mark and stays there. sometimes it creeps up higher then that, but for the most part it does not. i am wondering if the two are related. if anyone could help it would be greatly appreciated.
thanks in advance,
Derick F.
thanks in advance,
Derick F.
Troubleshooting the ASCD
thanks in advance,
Derick F.
thanks in advance,
Derick F.
Sometimes an ASCD won't engage because it mistakenly thinks it has been told to disengage. These are the disengage signals:
- Dashboard switch is in the off position.
- Driver steps on the brake pedal.
- Driver steps on the clutch pedal (5-speed).
- Driver presses ASCD cancel switch.
- Vehicle Speed Sensor indicates speed outside ASCD operating range.
Check each of these items. The location of most of these components is shown in the Chilton repair manual on page 6-11.
The brake pedal switch is probably the most heavily used component in the ASCD system. That's because it is operated every time the driver steps on the brakes, regardless of whether the Cruise is engaged. The part that works hardest is likely to be the part that fails first.
Check the ASCD relay in the engine compartment. (ASCD = Automatic Speed Control Device.) Relay box #1 is on the passenger's side of the engine compartment. Use a flat-blade screwdriver to release the latches and lift the relay box cover up and away. The legend on the relay box cover identifies the position of the ASCD relay. It is blue (5-speed) or brown (automatic transmission). All relays of like color are interchangeable. Exchange the ASCD relay with any other of the same color.
Verify that the wires and vacuum hoses which attach to the ASCD actuator are intact and connected.
There could be other faults (bad ASCD actuator, bad ASCD control unit) but these are less probable.
trasmadean
Feb 1, 2017 08:20 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
