Wheel Spaceing
Old Aug 12, 2001 | 10:13 AM
bben
I just installed a set of 16x8 rims on my 97 Maxima. The problem I am having is that the front rims/tires appear to stick out of the wheel wells more then the back does. Is there a problem with my rims or do I need to do something myself. I have heard somethings about rear wheel spacers? I would appreciate any advice.
Old Aug 12, 2001 | 03:12 PM
Chunger's Avatar
My other car is a Hybrid
The fronts do stick out more than the rear... You COULD put spacers in the back to fix the LOOK but it would probably screw up the handling of your car (probably more understeer). Nissan apparently made it that way to balance the handling of the car... There's nothing wrong with your rims (unless you got he overall offset which should be about 40mm)
Old Aug 12, 2001 | 03:28 PM
BRIGBOY's Avatar
So it appears the fronts are slanted?
[QUOTE]Originally posted by Chunger
The fronts do stick out more than the rear... You COULD put spacers in the back to fix the LOOK but it would probably screw up the handling of your car (probably more understeer). Nissan apparently made it that way to balance the handling of the car... There's nothing wrong with your rims (unless you got he overall offset which should be about 40mm) [/QUOTE
The fronts stick out more, yes, but is that because they are tilted outwards at the top of the wheel well?
Old Aug 13, 2001 | 09:10 AM
Chunger's Avatar
Re: So it appears the fronts are slanted?
I think he was refering to the track and not the camber... mine doesn't camber much at all
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
thenewguyy
Sep 12, 2015 11:12 AM
