0707 and 0304 sensors
Old Aug 14, 2001 | 06:15 AM
Max4U's Avatar
I recently changed my two o2 sensors in the front and now a month later i'm getting 0707 for the rear 02 sensor I reseted the ECU and the check engine light came back after I filled up the car with gas I then did the self diagnostic with ECU then I got 0707 and 0304 which is the knock sensor. If I change the 0707 will the 0304 code go away or do I need to do both?
THANKZ ALOT
Old Aug 14, 2001 | 06:48 AM
Daniel B. Martin's Avatar
THANKZ ALOT
Whenever you post a technical question it is helpful to specify ...
- model year
- transmission
- odometer reading
- mods (if any)
- recent repair history
- a detailed report of symptoms
I suggest you replace the rear Oxygen Sensor and reset the Engine Control Module. That one repair may resolve both codes.
Old Aug 14, 2001 | 01:25 PM
Max4U's Avatar
Thankz for the quick reply DBM but should I go with the nissan rear 02 sensor or can I use the after market sensor.
Old Aug 14, 2001 | 05:37 PM
Either will do. Make a price comparison between the factory part and the aftermarket sensors.
Read the first post in the Sticky 4th Gen Maxima Maintenance. You will see contact information for dealers who sell genuine Nissan parts at a discount. You may be able to get a Nissan sensor for the same money as an aftermarket item.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
