taking apart the APC clear tails
Has anyone painted their APC clear tails? I decided I've had it with my clears because I can't get bright enough bulbs to avoid that washed out look. So yesterday I got a can of that Vans paint to finally do this right and make em clear/red tails.
Anyways I looked over the rear of the housing noticing the four tab like things in slots (mine is the 95-96 tails). But when I try to pry them apart they dont budge. I'm afraid of breaking the darn thing. Doesnt look like you'd want to spray the paint inside through the bulb openings so seems to me that you have to take em apart. Thinking its some kind of work like heating up a few glue spots and undoing the tabs in a certain order. If anyone has done this please share your advice. Many thanks for help!
Dan
Dan
Try following these instructions. Although they're for the 97+ stock lights, I'm pretty sure they're similiar.
http://www.performanceix.com/how-to/...axima_tail.asp
You could do that and from far away it would look ok. But once you get up close, it looks horrible. And if it's cheap taillight spray, it might even come off in the rain. Eeech.
Originally posted by guitaraus
am i wrong to think that the paint should just go out the outside of the taillights? isn't it "taillight paint"?
cutting is the only alternative I think
The only other thing I can think of is cutting the taillight up with a thin motorized saw blade and glueing the clear top part to the oem taillight in place of the amber part. Should work with a good epoxy glue and **carefully** applying it. I may just do that if the paint doesnt turn out the way I like it to. But I'm clueless on whats the best way to fuse plastic together. Yet more research t'be done.
you can open up the tailights by putting them in the oven at 400 degress for about 5min. sounds crazy but i tried it with an old oem tailight that was no good. and when i took it out of the oven i pryed it right open with a screwdriver. if not you can send them to david l and he will paint them for you, he does excellent work the tailights look like they came out of the factory.
LED bulbs look like crap in the max's tails. Ive tried them already and found that the light doesnt fill the entire brake section of the lense.
As for the clear/red tails: i say ask around for David Lau's e-mail and ask him to do you a favor. I have mine done by him and they match perectly and have never faded after 2years.
look for your self:
Anthony
look for your self:
Anthony
DONT cut them open...... this sounds bad but it works.... this is what i did. Put the lights in the oven at 250 degrees for 5 mins... NO LONGER.. then lift the 4 prongs up and pull on the light... it will take a little work but it will finally come apart... the heat gets the glue in there to come apart quite nicely
SuDZ
Originally posted by SuDZ
I remember last time you recommended this. Nearly gave everyone who was gonna do it to there tails a heart attack. Did any of them end up following your advice?
SuDZ
SuDZ
ditto that
look for your self:
look for your self:
:here's are my clear tails at maxus:
http://maxus2001.tripod.com/P1010087.jpg
that didn't work
try this link
http://maxus2001.tripod.com/page3.htm
from the top left my max is two across and three down. anyway hope this helps.
doctorpullit
Apr 23, 2017 05:35 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
jchronis2552
Sep 21, 2015 05:52 AM
