Cooling System Service
Old Aug 15, 2001 | 01:14 PM
abnorm's Avatar
My car has 69k miles on it and I haven't yet done the Radiator drain and refill. I just recieved a coupon from Nissan for the cervice. What kind of benifit will that accomplish? Will I notice any difference?
Thanks.
Old Aug 15, 2001 | 01:43 PM
njmaxseltd's Avatar
Your checking account will be slightly smaller and your car will be much happier on hot days. Other then that, you will notice nothing.
Old Aug 15, 2001 | 01:48 PM
SunMax's Avatar
Or you can try to do it yourself.
1. drain the radiator
2. fill with water
3. close the radiator, and run the car for ~5 minutes
4. drain
5. repeat steps 2-4 couple times
6. drain the water, fill with 50/50 mixture.
You might want to put more coolant because during the process, you have more diluted mixture inside the engine block.
Don't forget to take out the reservoir and clean it.
Total process: <1 hour.
Old Aug 15, 2001 | 03:36 PM
Eric L.'s Avatar
It is recommended that the coolant be drained and refilled every 30k miles. I change mine every 15k. Lack of properly maintaining the cooling system will result in a rusted out radiator core, clogged water passages, and a cooked engine (over time).
I think Nissan's official recommendation is to first change the coolant at 60k, then every 30k afterwards.
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Maximeltman
Sep 28, 2015 07:19 PM
Socalstillen
Sep 26, 2015 12:01 PM
