Where to buy Porterfield pads
Old Aug 15, 2001 | 03:53 PM
BriGuyMax's Avatar
I recently purchased Stillen Slotted rotors and Metal Master pads...and I am NOT impressed AT ALL with the pads, you have to heat them up to get them to work well, but then soon after that they become too hot and start to fade BADLY.
I've heard nothing but good stuff about Porterfield Pads I just don't know where to buy them.
help please!
Old Aug 15, 2001 | 05:01 PM
Mishmosh's Avatar
uhh.. it's in the sticky. Buying directly from them is the best way so long as you call them and mention "Maxima group" prices.
Old Aug 15, 2001 | 05:08 PM
TarHeelMax's Avatar
www.porterfield-brakes.com but you have to call (800)537-6842 to order.
BTW, nice shine!
Old Aug 15, 2001 | 05:58 PM
Nathan's Avatar
I tried emailing those yahoos and they didn't even reply to my email. I'll probably phone them tomorrow to place an order. I heard that if you mention that you're a member of the maxima club they will give you a killer deal.
BTW, nice shine!
Old Aug 15, 2001 | 06:09 PM
Eric L.'s Avatar
help please!
Sorry to tell you, but a characteristic of these high performance pads is that they need to be warmed up a bit to perform optimally. I have the porterfields, and in the morning, I need to make a couple hard stops before they grab well. So, I'm not sure if going to Porterfields will necessarily improve your situation.
Old Aug 15, 2001 | 06:43 PM
TarHeelMax's Avatar
Eric, did you have to drill into your AP430's in order to install the return spring?
Old Aug 15, 2001 | 07:08 PM
Mishmosh's Avatar
That is what you will need to do if you want to install the OEM return springs (Porterfields do not have the holes). I chose to leave them off and have not had any problems with squeeling and such. I did use CRC Brake Quiet goop. As tight as the pads fit in there, I can't see how the springs would do very much... but I guess they were there for a reason.
Old Aug 15, 2001 | 07:22 PM
Eric L.'s Avatar
You don't need the return springs. The new OEM replacement pads don't even have the holes for the springs anymore, so it is clear that while it is nice to have, the springs are not necessary for proper brake function.
Old Aug 15, 2001 | 08:26 PM
TarHeelMax's Avatar
Thanks, Mishmosh and Eric L.
Old Aug 16, 2001 | 01:37 AM
BriGuyMax's Avatar
thanks for the replies guys.....I was in a rush today...and didn't have time to look through the stickies. I think the porterfields will work better....my current ones fade BAD when they heat up (after 3 or 4 hard stops from 40-50)
Old Aug 16, 2001 | 03:52 AM
OgreDave's Avatar
Im pretty sure the info is in the sticky, but just in case, make sure you get the group deal pricing.
If s/h is rediculous.. lemme know, im local.
Old Aug 16, 2001 | 05:20 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
I am forced to ask why you literally could not look through the sticky, yet had time to post? I'm pretty sure it would have taken the same amount of time. But I digress....
My bet is you bought these pads from Stillen, is that correct? If it is, Stillen has been known to not use true Axxis Metal Master pads, but rather knock-offs or even the "Deluxe Plus" organic pads, which will fade as you describe when they heat up.
The Axxis Metal Masters on both of my Maximas do not exhibit this behavior on standard (blank) Brembo rotors, nor did they exhibit this behavior when I used Stillen cross-drilled rotors.
Old Aug 16, 2001 | 11:01 AM
BriGuyMax's Avatar
Bill,
I was already on a "form to post" page before I even thought about the stickies...and that's my fault, but that page alone takes like 2-3 minutes to load during the day....and I didn't have time to go back to the 4th gen forum...wait for that to load, then click on the stickies, and wait for them to load. oh well....thanks for the help, and I didn't buy the pads from Stillen....I bought them from GR racing.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
