A/C not working right
Old Aug 15, 2001 | 05:57 PM
MaXAnDy's Avatar
Hey guys i wanted to know if you could help me out with this. I have a 99 maxima gxe and my A/C only works on level 4, when i put it anywhere else it is just off. I went to the nissan dealer today and they tried changing the *** and they did something under te glove box but it didnt work they said to take it back tomorrow. But if anyone can help i would appreciate it.
thanks
Andy
Old Aug 15, 2001 | 06:05 PM
Eric L.'s Avatar
Did you mean that your AC only works on 4 (i.e. no cold air on any other setting), or that the fan only blows air on 4? If it's the fan, then the blower resistor unit needs to be replaced. If it's the AC, I would check the AC pressure switch and clutch operation.
Old Aug 15, 2001 | 07:47 PM
Daniel B. Martin's Avatar
thanks
Andy
If your '99 is still protected by the warranty let the dealer handle this repair.
Old Aug 15, 2001 | 07:58 PM
thanks
Andy
There is a resistor assembly mounted on the air duct close to the blower motor. That part has failed. It is used to control fan speeds 1, 2, and 3. Speed 4 is the maximum blower motor speed, so no resistors are involved. Replacing the resistor assembly is something the home mechanic can do. The only tool needed is a Phillips screwdriver. The replacement part costs about US$25.
The blower motor is located just above the passenger's feet. Look at the wires leading away from the blower motor. Just inches away from the blower motor there is an electrical connector located on the air duct. That's the resistor assembly. It is easy to remove and replace.
Replacement is the usual remedy. However, if a spot of localized damage is seen it may be repaired with a soldering gun.
Old Aug 15, 2001 | 08:32 PM
MaXAnDy's Avatar
thanks for the help guys. I'll check it out.
Andy
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
