new brake pads still sqeal???????
Old Aug 26, 2000 | 09:42 PM
95goldSE
My brakes were getting wore down so I got some new ones and put them on my self, I've always done my own brakes but these still speal what the hell could it be???????
Old Aug 26, 2000 | 10:20 PM
maxmze
brakes squeal
i have the same problem.. i replaced my paads last week and cant get rid of teh squeel. i even cleaned them yesterday. i dont know whats up but if u find out let me know!!!!!!!!!
Old Aug 26, 2000 | 11:12 PM
Kenneth's Avatar
OG :)
The aftermarket pads tend to squeal more. Bought OEM?
Old Aug 27, 2000 | 02:14 PM
Eric L.'s Avatar
Nissan brakes tend to squeal if you don't install the new pads with new shims. I dunno why, but since most Nissan brake pad kits comes with shims, why not install them anyways?
Also I noticed that unlike other cars, the Maximas brakes squeal only when applied as a sign of the pad wearing out. On other cars, the brake wear squealing sound is heard when you are not stepping on the brakes, but rather when you begin to accelerate.
Old Aug 27, 2000 | 03:33 PM
my experience
i have swapped pads multiple times...always used the shim from the factory pad on the new pad if not provided...never a squeak
Robert
Old Aug 27, 2000 | 04:27 PM
ßaller's Avatar
Same problem too, had it replaced at dealer.
Don't know what's going on with them.
Old Aug 27, 2000 | 11:15 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
alot of aftermarket pads squeak.
The best you can do is use new shims, make sure all your surfaces are clean. Turn your rotors if they arent perfectly smooth. You can try disc brake quiet. can buy that almost anywhere.
Oh and pads are suppose to squeak when almost worn. thats the wear indicator.
Old Aug 28, 2000 | 07:55 AM
NeO OnE 2
95gold
Maybe you should of gotten your rotors shaved. I replaced my pads w/ these ghetto Raybestos I got form Pep boys and it sqeeked for about 400miles.... I figured that it made the noise 'cause I didn't get the surface shaved.
Old Aug 30, 2000 | 10:41 PM
Kenneth's Avatar
OG :)
i am hearing squeal without applying neither gas nor brake pedal. sorry no clutch pedal
its on my aftermarket pads and they are worn.
Old Aug 31, 2000 | 11:49 AM
humaras's Avatar
squeal
Yeah, my Max had the pad changed but unfortunately my car was brought to a shop that put in non-factory parts. It squeals in low speeds--such as when I am backing up the driveway. It squeals a lot though when the brakes are wet...oh well, guess I have to live with it for the next 20K or so.
Old Aug 31, 2000 | 12:45 PM
Kenneth's Avatar
OG :)
Re: squeal
i used aftermarket pads. now depleted after 15k.
brake quiet makes them shutup.
Old Aug 31, 2000 | 01:18 PM
Chebosto's Avatar
RIceD OuT moDErAtor
its not about the new pads it's what holding the pad in that make it squeal.
you can
1) remove the caliper, scrub down the metal clips that hold in the new pads and scrub away the dust on them along with the help of a brake cleaner spray
2) get brake pad LUBE, they sell at pep boys. it'll help lubricate the pads against the caliper to prevent squeeling.. JUST DONT GET THE LUBE inbetween the pad and the rotor.. that might be a BAD thing... i.e. whoa. what brakes..
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
