1998 max se speakers
Old Aug 23, 2001 | 07:19 AM
geoapzds
Anyone know what size speakers are in a 1998 SE?
I want to put the Boston Acoustic pro series components in my ride but I dont know which proseries set to purchase due to size!!!
Old Aug 23, 2001 | 07:29 AM
Vyrus's Avatar
RE: Speakers...
Do you have the Bose system or not? The non-Bose system has 6.5" holes cut in the doors and rear rack. Just trying to help.
Old Aug 23, 2001 | 07:38 AM
SuDZ's Avatar
Re: RE: Speakers...
I have heard that putting non bose speakers in with the BOSE system sometimes causes problems? Any one heard of this?
SuDZ
Old Aug 23, 2001 | 07:56 AM
BamaMax's Avatar
Each speaker in the Bose system has their own separate amp attached to them. If you replace one of them, you will have no sound coming from that speaker(s) unless you add an amp. The head unit supplies no power by itself. Someone correct me if I am wrong about this. I don't know anything about the non-Bose systems.
Old Aug 23, 2001 | 03:01 PM
gtr_rider's Avatar
192.168.1.1
Re: Re: RE: Speakers...
SuDZ
If your fortunate enough to find a match with the same wattage, and ohms, then it would be fine to do the swap, and still use the bose amp.
Your correct to the dime, when my amps in the back burnt the speakers did play, and they switched there power to another speaker, until I was fortunate to get a couple from my "Supplier"
Old Aug 23, 2001 | 03:55 PM
JUDE's Avatar
Yes, I had a friend who wanted to sell me his Bose system. I contacted Bose about the swap and they said that each system has its own circuitry and it was unadvisable to do it. Non-bose systems, like mine, come with 6'5in 15watt Panasonic speakers.
Old Aug 23, 2001 | 06:24 PM
Kevin Wong's Avatar
Actually
They are 6.75" or 6.5S. They are oversized and can be a hassle to find a good set for a low price. I replaced my rear speakers with the Infinity Kappas and my front components with Rockford Fosgate Fanatic Q's. They sound really good...enough mid-range to fake a sub. Actually it's the Fosgates that create a lot of the lows, the Kappas generate a perfect mid-range.
Old Aug 23, 2001 | 11:44 PM
MarcJD's Avatar
I replaced my Bose system speakers in my '98 SE with Boston Acoustics. I think 5.5" in the front and 6.5" in the back. If you are going to change the speakers I would suggest changing everything...the headunit and all...it might all work together better that way. Good luck!
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
