+50 mm offset
Old Aug 25, 2001 | 04:10 PM
Ruckus's Avatar
will these do fine on a 98 gxe? Rims are 16 x 7 with 5 x 114.3 and 4 x 114.3 dual lug patterns. i just bought them from sweetsound2001, so if you are reading this anton, i just want opinions. he says that they clear the brakes fine, he tried them on a 97 gxe. what i'm worried about is if they will rub against the fenderwalls when i take turns or whatever. i really really want to put these rims on, by the way anton describes them, they only weigh 15 lbs. each. check them out. the pictures aren't working anymore for me, but the description is still there. thanks in advance.
http://cgi.ebay.com/ebaymotors/aw-cg...247193&r=0&t=0
ooOORuckusOOoo
Old Aug 25, 2001 | 06:06 PM
got rice?'s Avatar
I'd be more worried about having the spoke not clear the caliper; the offset is going to make it inward more, so it's not going to be an issue rubbing the outer fender (this would be the case with more negative offset, like +30mm).
Old Aug 25, 2001 | 07:58 PM
I30CeFiRo's Avatar
Rims with a 50mm offset might be a little too close for comfort, especially on the turns. I'd go with a smaller offset
ooOORuckusOOoo
Old Aug 26, 2001 | 09:28 AM
MAC's Avatar
MAC
all depends on the spoke design.
my last set of volk av3's was 46mm, no problems.
another 4mm I don't think would be a problem.
although your back rims will set in quit a bit from the fender well.
I didn't like the look so I had to use some spacers to make the rears look "normal" w/ the fronts.
Old Sep 3, 2001 | 12:35 PM
Ruckus's Avatar
bump
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
