What is the "1.25" meant in the metric M10x1.25x40mm...
Old Aug 26, 2001 | 04:49 PM
ericdwong's Avatar
I was at pep boys today replacing nuts and bolts on my exhaust system, as well as a replacement stud and to get the bolts to release my brake rotor. Anyway, the measurements of the bolts included M8x1.25x35mm, M10x1.25x40mm (cat bolts), and the wheel stud was M12x1.25x.... I understand the M__ rating as the width of the bolt. What is that 1.25? the third dimension is obviously the length. I dont think its the threading either cause theres the course and fine designations as well. Nissan looks like they use alot of the M_x1.25 fine threading size. From my experience with Toyota, they use it too.
On a side note, I FINALLY got out one of the catalyst studs that was stuck stuck stuck. The way I did it was to heat up the one end with a roadflare, and then vice grip the other side. It came out finally and I was real excited. I then put my new bolts through a few times in order to clean out the threads. Now I'm gonna sandblast the cat and paint it with high temp paint. Another question, I can't seem to find (havent tried the dealers yet) a suitable replacement stud for the cat bolts that face the Y pipe side. Is it acceptable to just dispense with the stud and just use a bolt and washer?
Old Aug 26, 2001 | 05:09 PM
sinewave's Avatar
The 1.25 indicates milimeters per thread.
As far as your other question of using a bolt instead of a stud, I have no idea.
Old Aug 26, 2001 | 05:15 PM
got rice?'s Avatar
grade of the bolt x pitch x thread
yes to the 2nd question. squirt on an anti-seize grease to make it pull off easier the next time around.
Maxilano
Aug 31, 2015 07:33 PM
myaeger18
Aug 24, 2015 04:06 PM
Lime
Jan 27, 2009 05:32 PM
superdesi
Jun 20, 2001 10:35 AM
FroMan
Mar 5, 2001 02:22 AM
