koni's or kyb gr-2
Old Aug 26, 2001 | 07:23 PM
camaro1698's Avatar
I'm in the market fore new struts. What do you guys think kyb or koni's. I want a soft ride, but I also want to be able to drive pretty aggressively!!
Old Aug 26, 2001 | 08:44 PM
Gotrice4's Avatar
Question: Stock or aftermarket lowering springs or coilovers?
If you get anything aftermarket, the consensus is Koni's or the new to be unwailed KYB AGX adjustables.
The benefit of the AGX is no modification to stock struts, just bolt in and enjoy!!!
Old Aug 26, 2001 | 09:08 PM
riggy's Avatar
i was also debating that......i know ppl have been happy with konis but dont know about kyb.....im in no hurry so i guess i'll find that out too...
Old Aug 26, 2001 | 09:25 PM
camaro1698's Avatar
I'm keeping the stock springs for now, so what do you think??
Old Aug 26, 2001 | 09:26 PM
RedMax95's Avatar
hey does anyone know how much the agx will be running for, in other words $$$?
Old Aug 26, 2001 | 09:36 PM
camaro1698's Avatar
when are the kyb agx coming out??
Old Aug 26, 2001 | 09:43 PM
breaux124's Avatar
Hopefully the middle of september, but most probably later than that.
Old Aug 26, 2001 | 09:49 PM
buss95max's Avatar
kyb were suppose 2 come out 2 years ago
Old Aug 26, 2001 | 09:51 PM
RedMax95's Avatar
so do u think the gr2s are better than toks?
Old Aug 27, 2001 | 09:15 AM
DCmax's Avatar
I have the gr2s and I love them. The overwhelming majority of the people I know with Tokicos have or are planning on getting rid of them.
The kicker for me was when I friend of mine bought a set of gr2s used with 27,000 miles on them and they still ride great. Most people with Tokicos report harshness after around 10k miles.
Old Aug 27, 2001 | 09:31 AM
mzmtg's Avatar
Minister of Silly Walks
That would be me. My toks have lost all sense of rebound damping...
Old Aug 27, 2001 | 10:10 AM
camaro1698's Avatar
so do the kyb gr2 give a softer ride or a harsher. I've heard that the konis can be adjusted so that its a soft ride. are the kyb like that??
Old Aug 27, 2001 | 11:14 AM
mzmtg's Avatar
I've heard that the softest setting on the Konis is still much firmer than stock. Not that that's a bad thing.
We dont know about the KYB AGXs since they arent out yet.
The KYB GR-2 is a little firmer than stock.
Old Aug 27, 2001 | 05:31 PM
Ramius83
Yeah, well, my stock springs and stock struts ride just fine, kinda like a big old Lincoln Town Car, and the 4x4 gap lets me go off-road, yeeeeehaawwwwwww. But I am gonna wait for the KYB AGXs to come out since they can be put in without any modification and the rear struts can be adjusted without having the remove them like the Koni's. Good luck with what ever you choose.
Old Aug 27, 2001 | 07:37 PM
camaro1698's Avatar
are ythe kyb gr2 a pain in the *** to put on. I've heard the koni's are difficult to put on because they dont bolt on, do the kyb gr2's bolt on like the tokikos
Old Aug 27, 2001 | 08:46 PM
DCmax's Avatar
The gr2s and Tokicos are cake compared to the konis.
Old Aug 27, 2001 | 09:21 PM
lax99max's Avatar
Does anyone know if Bilstein's going to make some for Maximas?
Old Aug 27, 2001 | 09:42 PM
Dave B's Avatar
Not DAVEB the parts guy
Hey, I have both Koni's in the front and GR-2s in the back. I'm also running Suspension Techniques springs.
The Konis are MUCH firmer than stock even when on the softest setting. To put the Konis in will require you to cut the old strut, remove the internal and oil, slide in the the new strut, and bolt it down. From start to finish, installed and on my car, took 2 hours. The only fancy tools I used were a dremel and spring compressors. The Konis have been in for 1 year now. On the softest setting and pushing on the front end, rebound is about 1/2". On the firmest setting, rebound is hardly measureable...no joke.
My GR2s were installed 1.3 years ago and have 15000 miles. The GR-2s are a bit firmer than the stock SE struts and I believe they are superior to the Toks everyone uses plus they are much cheaper. After 15000 miles, they are still firm and hardly rebound (~3/4") with a forceful push from the trunk.
For a daily driver with no ambitions to either drag race or autocross, the GR-2s are by far the best set you can buy plus they are designed for the extra load of semi-aggressive (~1.7 drops) lowering springs.
Dave
Old Aug 27, 2001 | 10:35 PM
AdMax98's Avatar
Dave
So the Gr-2s wouldnt be able to handle Sprint springs (2" drop)?
Also are the new KYBs going to be fairly high priced like the Konis?
Old Aug 28, 2001 | 08:02 AM
Dave B's Avatar
KYB says that the GR-2s are designed to safety handle a 1.7" drop. If you go lower, then the struts will most likely wear out quicker.
The adjustable KYBs will probably be $130-100 each depending on front or rear. I choose to go with the GR-2s in the rear because I saw no point in having to remove my strut to make adjustments. I figured I'd just wait until KYB comes out with the AGKs. My front Konis should last the life of the car.
Dave
Old Aug 28, 2001 | 08:09 AM
Dave B's Avatar
Dave
AcuraLegend
Oct 17, 2016 08:47 PM
maxima-junky
Oct 7, 2015 06:13 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
