What brand of headlights does everyone use?
Old Aug 29, 2001 | 11:10 AM
Black97GLEnj's Avatar
I want all the lights on the front to match (or as close as possible). Anyone have a good combo for the headlights, corners, and blinkers? I'm looking for the bright white look, not the blueish look. Any info would be helpfull.
Old Aug 29, 2001 | 12:13 PM
Albertt's Avatar
Get Philips BlueVisions in your headlamps (9004) >>
and Philips BlueVisions or Premiums in the foglamps (H3).
Old Aug 29, 2001 | 12:17 PM
Canuck's Avatar
I think that the PIAAs match up well, and they are very white.
njmaxseltd's Avatar
Oh this is a good one. I've been through about 5 sets of the Super Whites to find the ultimate match. Here's what I wound up with.
Corners = PIAA Platinum Series Super Whites 27Watts - just grind off the tab and put them in 180 backwards to get the high wattage.
Fogs = PIAA Extreams 55Watts. Any more wattage in that small space and they burn out to quick. These have an excellent light!!
And last but not least, after SEVERAL sets of the blue crap super hyper white ZENON junk I wound up with Diamond Blue "HALOGEN" 80/100 watt bulbs from JC Whitney. These lights have a very bright WHITE light. I see no blue on the road at all. This setup is very bright and very white. No blue tint anymore. I've played around with quite a few sets of the hyper white "ZENON" blue junk. Stay away from them the light is not so good and you can't see for $hit in the rain with them. Check out JC Whitney on line and look for the Diamond Blue Halogen bulbs I went for the 80/100 watt bulb, they also have the standard 46/65 Watt as well.
Old Aug 29, 2001 | 06:15 PM
j_bryan's Avatar
what do you use for the front side marker light (the light below the cornering light)? the front side marker light comes on with parking lights and with the head lights...do these match up well since you have the higher wattage corner light set up??
Old Aug 29, 2001 | 07:09 PM
bolido2000's Avatar
I use Showoff krypton for the headlights, and eurolites for the corners. They much up pretty good. Very white.
Old Aug 30, 2001 | 05:39 AM
njmaxseltd's Avatar
Just the plain old orange marker bulb. I have the clear lenses in front, they must flash orange in NJ.
Old Aug 30, 2001 | 06:47 AM
CheshireCat76's Avatar
Im running PIAAs for heads.
Polargs for clearance and marker lights.
The PIAAs dont match up well with the Polargs which have a more white with blue tint to them. Which is what i want.
I need to find headlights that will match up with the Polargs. If anyone has the polargs and found a brand bulb that matched please post and let me know.
BTW I rewired the clearance lights so that they run at 21W.
Old Aug 31, 2001 | 11:47 AM
anybody??
Old Aug 31, 2001 | 04:57 PM
amixam98's Avatar
Needs non-Maxima Friends
I'm using Hiper Industries for my heads and polargs all around. Hiper Industries also make corner and side maker bulbs...
Old Aug 31, 2001 | 06:44 PM
NightRider's Avatar
APC Superwhites match up with Polargs. I'm running Piaa Platinum bulbs right now. I've had them for four years now. I'm waiting for them to burn out.
Old Sep 1, 2001 | 01:45 AM
TurDz's Avatar
redmax 007 has a perfect match. Phillips BlueVision on headlights/fogs, pepboys generic hyper white bulbs for everything else.
here's a pic
Old Sep 3, 2001 | 07:44 AM
j_bryan's Avatar
here's a pic
looks good, but is that standard 55w? looks to be a higher wattage than stock--the light is quite white (not blue)..
now if only that front turn signal light wasn't amber...
Old Sep 3, 2001 | 08:41 AM
NYCe MaXiMa's Avatar
Hey guys...
I'm looking to do some lighting upgrades... What is a good place on line where I can order what I need relatively cheap and has a large selection?????? thanks.
Old Sep 3, 2001 | 09:54 AM
amixam98's Avatar
Re: Hey guys...
www.importtrenz sends Hiper Industries bulb for $19/pair, if you are interested. That's what i'm running right now. They also have H3 for your fogs to match.....
Old Nov 24, 2001 | 10:30 PM
AT LAST!!!!!!!!!
here's a pic
THAT... is what I want... damn, I must have read at least 30 lighting posts....
I have wasted a lot of $ on trying to match my lights up... My headlights are whiter then stock but are still a tiny bit yellow... I have Xenon hyper white clearence bulbs now which are more bluish-white then the headlights... redmax has them PERFECT.....
Redmax, what parking lights are those?????? I didn't find any hyperwhites at any local pepboys/autozones etc.. The headlights look perfect for what I want, just white, no blue... now i need white parking lights... damn, I have definately wasted over 100$ on picking lighting now.
Old Nov 24, 2001 | 11:01 PM
metallic97gxe's Avatar
Master Will
EUROLITE
-XENON EUROLITE(#1157-Park Lights,27W Output)
=$4.50 Each-Bought New From AIEOnline.com.
-XENON EUROLITE(#194-Side Markers)=$8.00 A Pair-Bought New From AIEOnline.com.
-XENON EUROLITE(#9004-45/65WHeadlights)=$17.00 A Pair-Bought New From AIEOnline.com.
they match good enough for me make sure you rewire your park lights though
Old Nov 24, 2001 | 11:54 PM
Re: EUROLITE
thanks
Do they give off a slightly bluish light?
Because I think the parking/clearence Xenons I have right now are the Eurolites and they have just a slight blue in them, nothing bad.. i like it actually, but i gotta make sure everything else matches them.. so do they have some blue?
Old Nov 25, 2001 | 02:53 AM
TurDz's Avatar
NYCe,
Those are a combo of Phillips BV HL/Fogs, and those ARE the generic kinds you find at PepBoys. I've been to 2 PepBoys so far and they've both had the bulbs. They should be 1157, dual filament.
Old Nov 25, 2001 | 04:07 AM
black019's Avatar
piaa headlights
eurolite everywhere else
Old Nov 25, 2001 | 06:16 AM
Vyrus's Avatar
Naxis Xenon Blues...
I've had them in for 3 months and NO problems evem though they're 100/80 watt. The bulbs look blue but project the whitest light you can imagine.
-Cyrus
Old Nov 25, 2001 | 08:43 AM
Master Will
Re: Re: EUROLITE
thanks
the headlights are blue when they shine on something like a wall and when other cars see you coming at them but you as the driver they are not blue....the "middle" of the light pattern is "hypwerwhite,superwhite" and the outter part of the pattern is blue
the park lightsa and side markers have no blue tint at all...they are a clean white and bright...
of cource they are blue when they are off
http://www.aieonline.com
I have had them for a very long time and I really like them...
Old Nov 25, 2001 | 09:07 AM
NYCe,
does the bulb itself look blue? I've been to Pepboys and they have just regular factory replacement clear bulbs, I don't know if those will work like that, I figured they will be like stock so I didn't get them... thanks
Old Nov 25, 2001 | 09:18 AM
Master Will
yes they are blue when off but when on they are not blue
page 2 at the bottom of the page...
these bulbs are "tinted" blue and not "colored:" blue as in "blue,Blue"...it is hard to put it into words
http://maxima.cardomain.com/member_p...d=24211&page=2
Old Nov 25, 2001 | 10:26 AM
Weasel's Avatar
I know what you mean, the BlueVisions are like that... they're tinted just enough to get rid of the yellow portion of the light but they aren't tinted so much that they look blue.
Old Nov 25, 2001 | 07:12 PM
phatmax95's Avatar
does anyone have a matching setup with bluish bulbs? and.. Phillips BlueVision on headlights/fogs, pepboys generic hyper white bulbs for everything else. how much does this setup cost?
Old Nov 26, 2001 | 07:09 AM
breaux124's Avatar
You should be able to find the Philips blue vision bulbs at Kmart. I think they are around $9 per bulb, so
Headlights = $18
Fogs = $18
These are estimates, I'm not sure how much the generic 1157's are. Every pep boy's I've seen, I think the 1157s are made by APC.
Old Nov 29, 2001 | 12:49 AM
TurDz's Avatar
Headlights = $18
Fogs = $18
The APC ones are usually around $6 - 8.
Old Nov 29, 2001 | 10:33 PM
Ndo125's Avatar
Just Installed Philips Blue Vision
Just Installed them......first impression... Disappointed
I wonder why people claim this as one of the best light bulb in market.............
Is there any break in period for this bulb??
Because....
First,
It's not a lot brighter than my stock... probably just 5% brighter.......I compared them side by side... just now.....
Second,
It's not blue/white at all.... Its still kinda yellow.... like stock...... not much different in color.....
Old Nov 30, 2001 | 06:37 AM
MaximaRider's Avatar
i have Philips BlueVision in my headlites, i was kinda dissappointed but for 9.99 the pair it didn't really hurt me, and my fogz are PIAA Super Plasma H3's, sick fogs for $60.
Old Nov 30, 2001 | 07:29 AM
Im running Nokya's for heads now with
the upgraded harness and PIAA's
for the side markers and clearance lights.
Old Nov 30, 2001 | 08:35 AM
nismo2020's Avatar
im running hiper industries 9004s and piaa hid 1157s. blinkers are stock but blacked out lens.
Old Nov 30, 2001 | 08:52 AM
Ndo125's Avatar
Do you think its worth the money to get PIAA super whatever...?
or....
Is it better just to get the wiring harness? and Install higher wattage light?
how much is the wiring harness? where to get? how to install?
Old Nov 30, 2001 | 08:54 AM
Kyle7475's Avatar
I'm running Eurolite in everyting. http://www.aieonline.com they match up good but the 9004's are blue
Old Nov 30, 2001 | 09:02 AM
ny96max's Avatar
im running:
Piaa SW 9004 (65/45) headlights
Piaa SW H3 (85watt) fogs
Polar-G 1156 (rewire corner lights)
and 194 marker lights
Polar-G hyper red taillight bulbs too!
Old Nov 30, 2001 | 10:38 AM
breaux124's Avatar
or....
I have the piaa superwhite 9004s and piaa xtreme h-3 fogs. The Piaa xtremes are worth the money, but the superwhite for the 9004 aren't in my opinion.
I've actually purchased a wiring harness and I'm in the process of ordering higher wattage bulbs from www.jcwhitney.com
The wiring harness is really easy to install. You can buy it from lots of places.
www.jcwhitney.com
http://www.autodynamic.com/
http://www.modacar.com/index/
http://store.yahoo.com/dpstore/
The harness cost around $40-50.
Old Dec 1, 2001 | 08:01 AM
Supa Lao's Avatar
I'm running Nokya artic purple w/ apc corner bulb that I rewired and they are both high wattage. Those things don't match up at all Apc corner bulbs look very blue compared to my headlights. Blew a fog light, so I don't know what kind to get right now for them.
Old Feb 27, 2003 | 10:26 PM
BOZOnPJs's Avatar
so which ones did you get?
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
MaxLife17
Sep 8, 2015 02:36 PM
