Won't Start--Help!
Old Sep 1, 2001 | 04:50 AM
tonymich's Avatar
My 95 SE won't start. Here's what it does. Turn the key, dash lights come on; quiet clicking in the cab. No noise under the hood. Tried to jump start it...no good. Any Ideas?
Old Sep 1, 2001 | 07:30 AM
cbr2's Avatar
ok
Get a broom handle and hit the strarter w/ it...
That should work.. If it is a manual push start it..
Old Sep 1, 2001 | 08:18 AM
Daniel B. Martin's Avatar
You are reporting a no-crank problem.
Always do the easy check first. If your vehicle is a 5-speed, make sure the clutch pedal is all the way down when you twist the key to START. If automatic, jiggle the shifter while attempting to crank. Try cranking in both Park and Neutral. If those steps are unsuccessful, consider ...
- discharged battery (dim headlights with engine off)
- weak battery (check voltage at terminals while cranking)
- loose or dirty battery terminal connections at the battery
- loose or dirty battery-to-body ground connection
- loose or dirty battery-to-engine block connection
- bad ignition switch
- bad clutch safety switch (5-speed)
- bad neutral safety switch (automatic)
- bad inhibitor relay
- bad solenoid
- bad starter
The starter is an expensive item so you should check the other items before spending the money on a replacement. Unfortunately, the '95s are known for weak starters so that might be the root cause of your no-crank.
Sep 27, 2015 08:37 AM
msellas
Sep 23, 2015 09:16 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
markevans999
Sep 10, 2015 04:29 PM
