Y-pipe installed, hearing noise in 1st!!
I've just installed my stillen y-pipe! I hear hitting/vibrating noise in 1st while accelerating. I have not fully investigated this. Looking for the quick fix! Has anyone experienced this?? Also, have r.t. cat and stillen cat back.
Originally posted by breaux124
Check the bracket around the Y-pipe / Cat junction (the one with the rubber hangers). If it's too far to one side of the car it might be hitting the body. You should be able to bend it and then it won't hit anymore... at least that worked for me.
That is the general area of the noise. The bracket you are refering to, is it the one that holds the rubber hangers. as you already know with R.T. cat I no longer use the hangers. Do you believe there's that much lateral movement between flex sec. and the cat?
Yeah the bracket with the rubber hangers. There is only one bracket where the Cat and Y-pipe meet.
Why can't you use the hangers? Even with the RT cat the hangers are used at least with my RT cat and Y-pipe.
My cat doesn't have the little hanging nubs!
The cat is bolted to the B-pipe in the back, and then bolted to the Y-pipe in the front.
The bracket that I'm refering too is in the front, where the cat and Y-pipe meet. This bracket is actually looped underneath the flange of the RT cat and the bolts go through it.
Look at this pic.
http://www.greghome.com/images/Maxim...oveCatNuts.jpg
If you look at the top of the bracket, near the rubber hangers on both sides, it might come in contact with the body of the car. This is what you have to bend.
I think you are getting something confused.
Look at this pic.
Look at this pic.
This bracket is no longer existing on my car, it came off all at once with the rest of the stock exhaust. Then was replaced with an R.T. cat and y-pipe
Originally posted by KCTYPHOON
umm.. just to inform you man.. the r.t. cat is not suppose to replace that bracket.. your suppose to take it off and reuse it.. your better off buying a new one, its about 35 bucks from nissan. i have the exact same exhaust as you, and something is also hitting in that area( along with the two other places it was ratteling),some im not so sure its the bracket thats hitting, but you really should put it back to take the stress off the flex section.
Greenmaxspeed
08-31-2015 09:06 PM
MaximaDrvr
08-19-2015 08:20 PM
