Door Panels
Old Sep 7, 2001 | 06:21 AM
asianmotorsports2000's Avatar
Anyone know how to remove the door panels on a 95 Max SE?... I found the two screws under the door pocket and the one in the pocket on the arm rest... I also popped loose all the fasteners behind the panel but I cannot get the panel off... Please help!!!!
Old Sep 7, 2001 | 06:52 AM
Daniel B. Martin's Avatar
Go to http://soundvision.homestead.com/fil...ll_sheet_5.jpg
Old Sep 7, 2001 | 06:53 AM
jiaxima96's Avatar
Another thing to be taken off is the plastic trim around the door open handle, with a flat head screwdriver. I believe for the front door panels, you should pry from the front side until the trim spring comes out a little. Then slide this trim towards back of the car meanwhile pull the trim out towards yourself.
For the rear door panel, pry from rear side, ... slide towards front, ...
Then you want to lift the door panel straight up and it should come loose. Please don't forget to disconnect the wiring connections behind the panel.
Old Sep 7, 2001 | 07:01 AM
jiaxima96's Avatar
Sorry for some reason my PC was very slow running and I didn't see Daniel's reply. Also I got something wrong in my post so please ignore it.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
