Bleeding The Clutch??? Help
Old Sep 7, 2001 | 07:17 PM
ICEMAN's Avatar
OK GUYS PLEASE HELP ASAP MY CLUTCH GOES ALL THE WAY TO THE FLOOR!! THE FLUID WAS OUT SO I PUT MORE IN IT BUT, I NEED TO KNOW WHERE TO BLEED IT!!!! UNDER THE HOOD OR UNDER THE CAR??? PLEASE SOMEONE HELP ASAP!!!!
Old Sep 8, 2001 | 05:38 AM
JohnnyMax's Avatar
1st where did the original fluid go?, fix this first.
Then there are 2 bleeders, one on the slave cylinder, then a 2nd on the drivers side fender under the hood.
Good luck
Old Sep 8, 2001 | 08:31 AM
Daniel B. Martin's Avatar
1) Please use lower case when posting on this forum. Posting in all capitals is a violation of Netiquette. It makes people think YOU ARE SHOUTING!
2) Go to http://www.motorvate.ca/
In the left window click on Transmission.
In the left window click on Clutch Bleeding.
This site is excellent for the home mechanic. You may like to browse it.
JohnnyMax gave good advice. Don't ignore a leak, fix it. Here is an idea of how you might do this.
Replenish the clutch master cylinder reservoir with brake fluid. Have an assistant sit behind the wheel and pump the clutch pedal repeatedly. The engine does not have to be running for this test. You look under the hood and under the car, searching for the leak. I'll bet it is in the slave cylinder. If you like to do your own "wrenching" you may rebuild the slave. PartsAmerica.com lists a rebuild kit, Raybestos CSK1038, for $8 plus shipping. Figure another $2 for some brake fluid, and you can get your car back on the road for $15 plus your time.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
