headlight problem!!!!!!!.....please help!!
Old Sep 8, 2001 | 02:12 PM
patel_anu's Avatar
i have a problem wiht my headlights, everyime i try to turn them on at night, one or both of them don't turn on at all, i have to open the hood and mess around wiht the harness and then they turn on and never turn off until i turn the car off and the headlights off. What's wrong wiht the lights??.......i do have xenon hyper whites, if that makes a difference, someone please let me know, thanks
anu
Old Sep 8, 2001 | 02:39 PM
Daniel B. Martin's Avatar
anu
Examine the headlight bulb sockets for signs of overheating (scorched or melted appearance). Repair as necessary.
When the headlights fail to turn on, wiggle the column-mounted headlight switch ON and OFF several times. There may be a burned contact in that switch.
Did you install the aftermarket lights with an auxiliary relay? If so, check that relay.
Has the headlight circuit fuse ever blown?
Old Sep 8, 2001 | 02:46 PM
patel_anu's Avatar
yeahh the brackets do get really hot, i burned my finger when i touched it so yeahh it does get really hot, wat can i do to fix it, are there any specific methods??.....thanks
anu
Old Sep 8, 2001 | 03:13 PM
thebigsadler's Avatar
I can almost guarrantee you are burning the stock harnesses out. I recommend getting it checked and if they are burned out and melted get the APC wire harness, easy install and allows higher wattage bulbs. It is 326.46 from nissan to repair the harnesses.. I did it once..
Old Sep 8, 2001 | 04:01 PM
sickmen's Avatar
Are you using the 100/80W bulbs on your max?
If yes, then you've to change the harness to havey-duty one and they cost around $30~40.
Shop around...
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
