Filter cleaning for JWT intake?
Old Sep 8, 2001 | 06:01 PM
syc's Avatar
syc
Hi! I installed a JWT air intake last week. The sound was great! I was wondering, since I heard that it is a not a genuine K&N filter, what filter is it anyway? Does this filter has any disadvantage over the real K&N one? And can I use the K&N cleaner package to clean the filter? or do I have to use something else. I don't mind buying a new K&N one in the future (like a year later or something). One last question, can I buy a bigger size filter since the cone filter itself is not occupying the whole space after the removal of the OEM air filter box. Thanks!
Old Sep 8, 2001 | 07:51 PM
WizzaMax's Avatar
Originally posted by syc
Hi! I heard that it is a not a genuine K&N filter, what filter is it anyway?
Not sure what company it may be but mine is genuine...
[i]Does this filter has any disadvantage over the real K&N one?[/B]
No disadvantage likely...
[i]And can I use the K&N cleaner package to clean the filter or do I have to use something else? [/B]
If the construction is similar, then the recharge kit should work fine for around $11.00 a set...
[i]One last question, can I buy a bigger size filter since the cone filter itself is not occupying the whole space after the removal of the OEM air filter box.[/B]
Just out of curiosity, did you remove the entire stock airbox assembly or set the JWT inside the lower airbox half? Just IMHO, for aesthetics, any filter much larger and possibly untapered would work fine but not look proportional to the rest of the engine bay...suggestion is leave the big honkin filters for the SUVs.
Old Sep 8, 2001 | 08:44 PM
Eric L.'s Avatar
My guess is that the filter is made by the same company that makes filters for K&N. Yes, you can use the K&N recharge kit with this filter. I do that.
Old Sep 9, 2001 | 03:10 AM
syc's Avatar
syc
I removed the entire stock airbox. I don't think there is enough space if I don't remove it. beside i need one of the screw hole to install the mounting bar that came with the JWT intake. i'm a newbie, i might be wrong.
Old Sep 9, 2001 | 06:40 AM
Micah95GLE's Avatar
You can leave the lower half of the stock airbox in. I did, and the Popcharger fits fine.
cruce91
Sep 20, 2015 10:23 AM
aminus21
Sep 12, 2015 04:53 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
