Upgrading spark plugs and wires
i am looking to do some simple modification to increase horsepower, I have been told the first thing to do is replace the sparkplugs with some better ones and get thicker wiring. Where would i buy this and what types or brands would i be looking at. Also what are other simple mods like that which would yeild small hp gains but when all added up would make and impact. Maybe something with the ignition. I am also looking to get the 60K tune up, would i just tellt he people doing that to upgrade the plugs and wires or would i be ripped off? thanks eric
hey, some simple mods that you could do before the sparkplugs and thicker wire could be your airfilter. get something like a K&N cone air filter. it'll give you about 5+ hp. i can tell you it's much better than the stock air filter in our maximas. then try to go for the y-pipe and the cat back system. those would give you some good hp too. i'm a newbie as well, so i could be wrong. but from what i hear, those would be some good starters... but hey, i would recommend the bosch sparkplugs. have fun.
i have a CAI and i have on the way a greddy catback system. y pipe will be for next year, but im pretty much lookin for simple things that will not hurt the engine and i can do within my budget. thanks for you input.
Changing your sparkplug wires is not possible on a 4th gen, we have coil on plug ignition, our "sparkplug wires" are the thick black things on top of your engine and should last the life of the car.
Bosch spark plugs are probably a bad idea too, people (myself included) have had problems with them, stick with the stock NGK plugs and you'll be better off.
So let me ask this because I can't read between the lines...at all, I wear glasses and stuff.
We cannot, change out our plug wires? I've seen some at Autozone (if I remember correctly) they weren't cheap but they said that it was compatable. Why do you suggest not using other plugs? My car came with Bosch from the factory(infiniti). I'm just wondering why, I've been told to use colder plugs when I switch to NOS (i don't understand that either)... please help.
I was gonna change mine with bosch with the next tune up
We cannot, change out our plug wires? ...
The VQ30DE engine uses coil-on-plug direct ignition. Each cylinder has its own ignition coil. The coil is packaged "in the hole" with the spark plug. There is no need for a wire to connect them because they are in direct physical contact. This modern design eliminates the need for a distributor. You will never need to replace a distributor cap or rotor for the same reason... your engine doesn't have those parts.
Just a thought if someone can answer for me... what about the different tips? Do you want something that creates a hotter spark? because they have the iridium ones and the split tipped ones... Where is daniel B to answer this stuff? or tilley? Medicsonic? All of you guys seem to know whats good or whats not. Help !!!!
Spark plugs don't make a "hotter" spark. The ignition coil and supporting circuitry does this. There is no reason to think this is a performance-limiting factor with our engines. The spark you already have is plenty hot.
The value of platinum or iridium tipped spark plugs is durability, not performance. The new RAV4 engine is factory-equipped with iridium tipped spark plugs and Toyota calls for replacement at 120K miles. Some technicians worry about ripping out the threads when they attempt to remove spark plugs which have been installed in an aluminum cylinder head for that long.
Crapola
Oh, ok. Doesn't stillen offer an ignition mod though? whats that all about?
magnets? I'm not even going to ask.
I want to laugh, but then I think about where all those microfibercarbons(whatever they are called) are going...
With the talk about fuel injectors, comes the questions about liquid fuel injectpr cleaners///stp/mobile... what do you think about them?
Originally posted by MAXEJA
so are there any upgrades for the 60 K tuneup that will actually make a difference in h/p, or is the only differnce just going to be in the tuneup itself?
Regarding the above questions about ignition systems, you probably wouldn't need any more powerful of a spark until you are running a supercharger since higher pressure mixtures are harder to ignite.
Most modern cylinder heads are designed in mind for a flame front generated by a traditional spark plug electrode.
Those BOSCH+4 plugs might likely create a very differnt flame front -- might create localized hot spots on the tops of pistons... maybe it generates frequencies that "fool" the knock sensors.
All of those "high performance" plugs, wires, etc.. are best left with old cars... since virtually any aftermarket parts for a 70's era car is an improvement.
Originally posted by cerumo
bosch sparkplugs give you problems? Can you explain why?
Re: Fuel Master
Originally posted by rupinsjo
Does the Fuel Master really work? Is it hard to install? How long until you have to replace it? Can it cause any problems?
Sounds too good to be true.
Originally posted by mcros
Go with the Denso Iridium plugs. Denso is by far the best spark plug made. They can be hard to find but, well worth the effort.
