air cone filter vs air intake
Old Sep 9, 2001 | 01:46 PM
itsgt's Avatar
Hi all,
I'm a little unsure what is the difference between the air cone filter and a air intake system.
I know that the air cone filter looks like a cone-like shaped cylinder that you place instead of the stock air filter under the hood on the driver's side.
What is the difference between these two things, which is better, how much hp does each item increase, and how/where does the air intake system connect to the car?
Old Sep 9, 2001 | 02:52 PM
SLC I30t's Avatar
they say you get like 5+ HP out of a cone filter. I doubt many people were that intrigued with just a filter exchange to do a before and after dyno...but I think Stillen claims 5-7 with a K&N style cone filter.. I think JTW claims about the same. I could tell a differenc, mostly in sound. But there is a difference in performance in my opinion.
Old Sep 9, 2001 | 03:28 PM
cooler2000's Avatar
interesting question! because i am planning to buy same thing since i see it is selling on ebay for 65 bucks and i can pick it up since seller lives nearby to me here in NY what he sells is JWT pop charger, same one selling on custommaxima.com for 115 bucks which is pricey!
Old Sep 9, 2001 | 03:42 PM
Vesaijan's Avatar
Hey, I saw the same thing. I think it actually said JWI intake, and it didn't look like a JWT, but more like a generic cone with MAF adaptor.
I was wondering...with a setup like that, where there is most likely no attachment spot for the air temperature sensor, what do you do with it? drill holes or zip tie it somewhere?
Old Sep 9, 2001 | 03:54 PM
cooler2000's Avatar
nope, you just take out your stock airbox and bolt this JWI setup into place of stock airbox, so all sensors stay at their places. all work takes 15 min to do.
I am thinking abt buying it if seller will allow me to pick up because he has bad feedback.
Old Sep 9, 2001 | 04:04 PM
SLC I30t's Avatar
just use your box bracket as a template and drill the new holes in the back of you plain aluminum intake end (should have a pre cut whole) then attach it to the MAF with the sensor still attached...
Old Sep 9, 2001 | 04:23 PM
itsgt's Avatar
Guys you got off the subject, i need to know what the difference if any between an air cone filter and a air intake system.
Exactly what is the air intake system and where does it go under the hood, same place as old filter or no?
thanks
Old Sep 9, 2001 | 04:30 PM
SLC I30t's Avatar
You remove the stock air filter box. it goes in its place.
Old Sep 9, 2001 | 05:05 PM
itsgt's Avatar
ok i know that a air cone filter goes in place of a stock air filter.
But what is a air intake?
Old Sep 9, 2001 | 05:28 PM
SLC I30t's Avatar
Your cone filter is an intake... your stock intake actually takes place near your grill... it looks like a black scoop with some foam around it... near your hood locking mechanism. If you replace that, you'll take that box out and you'll just have the cone filter intake in its place. you benefit from this because you have a larger surface area for air to pass into your engine, and you reduce the resistance and distance that the air has to travel to the engine... example... drinking through a swizzle straw (used for stirring coffee) and a short fat straw. You can drink more faster through the short fat one... less resistance and distatnce to where you want it to go...
Old Sep 9, 2001 | 06:51 PM
ZXdude's Avatar
your missing the question... he wants to know if there is any difference between buying a K&N cone filter from lets say pepboys VS buying a JWT or STILLEN "INTAKE" and i would also like to know the answer too. Don't the stillen and JWT intakes come with mounting bracktes while the K&N you buy at pepboys doesn't?
Old Sep 9, 2001 | 08:10 PM
itsgt's Avatar
yea, that sounds more like what I'm trying to find out, and also is a CAI same as a JWT/STILLEN "INTAKE"?
thanks.
Old Sep 9, 2001 | 10:46 PM
190hpKiLLA's Avatar
Granny Driven
thanks.
You dont have to drill a whole with JWT intake!I am selling JWT Pop charger. I only used it for 2 weeks. Nothing wrong with it. I need monney for books in college. It will fit 95-99 maxima. Custom maxima sells it for $114 shipped I will sell it for $100 shipped anywhere in the United States. Thanks. "E-MAIL viper10v12@aol.com"
Old Sep 10, 2001 | 04:26 AM
SLC I30t's Avatar
I already posted that Stillen/K&N(same filter)/JTW all report the same ratings for increased flow and power. CAI, some people don't believe in the CAI for the Maxima. The CAI in the maxima places the the filter behind the bumper, where there isn't real good airflow, but the air is cooler than in the engine compartment. There is also a Weapon R intake to take a look at too. I have a K&N, and I had to drill into the adapter to fit mine. Be sure to buy a bracket(if one doesn't come eith it) to keep the filter from rubbing and vibrating on your wheel well.
Old Sep 10, 2001 | 05:46 AM
itsgt's Avatar
how wide is the K&N filter? is it 6"?
Because I'm planning to install a 3" generic air cone filter with some Mods but a considerably lower price. So will there be a big difference between a K&N and the 3" im going to install, meaning is it worth getting the K&N instead but putting in more money?
thanks
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
