Help needed, car alarm electrical problem
Hi all,
After I did the cornerlight mod, which is to increase the wattage. My alarm no longer triggers the light blink when i turn it on or off. it still unlock and lock the doors, and still makes the chirping sound. But it doesnt make the lights blink when i turn it on, and when i turn it off. which it used to do before. Any help would be greatly appreciated.
thanks
thanks
by cutting off one of the nubs on the bulb, you have altered the cicuit, and therefor the way that cureent flows through it. With the bulb mod, the lights will not flash unless you rewire the corners.
more question...
how do i rewire the corner? is this information available on the this website? under rewire corner light?
what other option do i have? if i replace the stock bulb which has been modified, to an aftermarket bulb with both nubs, would that replace the original current flow?
thanks
thanks
Originally posted by maomoa
Hi all,
thanks
Hi all,
thanks
all my lights work. they just do not work when i turn on and off the alarm, there is no blink. does that mean its the fuse?
Originally posted by Ravq
Check the fuses. This happened to me when I installed some fog lights. It just happened to be a 10amp fuse in my situation.
Lakersallday24
06-16-2019 01:35 AM
TonyJr
08-20-2015 12:14 AM
kirkhilles
08-08-2015 10:53 AM
yat70458
08-03-2015 01:16 PM
