Main Fuse Block bolt with orange indicator
Old Sep 15, 2001 | 01:04 PM
cpumechanic's Avatar
It appears that if this bolt is loose, the fuseblock is poorly grounded. So.... the ignition relays do not work, and not much else works. What is the purpose of this bolt, and how do I "read" the orange locking tab , service manual is unclear on this. Thanks in advance for the help/advice.
Old Sep 15, 2001 | 01:51 PM
Daniel B. Martin's Avatar
I respectfully disagree. The service manual is very clear on this. It says ...tighten bolts until orange "fulltight" mark appears and then retighten to specified torque as required. The torque spec is 26-43 inch-pounds. The service manual continues ... Caution: Do not overtighten bolts, otherwise they may be damaged.
Old Sep 15, 2001 | 02:22 PM
Ok, you are correct, I did not state my issue clearly, the manual says what you say, but tells me nothing about the purpose/function of this very special bolt with the orange tab. Orange tab seems to be visible at all times even with the bolt finger loose. More interested in the function/purpose of this bolt.
Again, help on understanding this bolt greatly appreciated.
That is my minor issue with the otherwise excellent service manual for this car.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
salty318
Sep 28, 2015 07:22 PM
