coolant sensor knock sensor
install on coolanst sensor easy: ecu code 13
istall knock sensor: ecu code 34
w/ the right tools easy, w/ the wrong tools it's a real pain in the ***. everything is pretty straight forward as far as removing the manifold an disconnecting all the various vacume lines. the trouble starts when you have to remove the bolts on the manifold support brackets and the EGR pipe. space is very tight behind the motor so getting a ratchet in is difficult. aside from that everything else is simple.
just info for those who may need it. i saved my self $130 in labor charges.
my03maxima
Jul 28, 2024 07:40 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
