Spring Question????
Old Sep 21, 2001 | 07:08 AM
njmaxseltd's Avatar
Spring Question????
I've got a set of H&R's coming and I've seen some guys talk about doing the job without a spring compressor. How exactly is the job done without the compressor? Is the spring actually easy enough to compress with just some force?
Any feedback and detailed disassembly / assembly info. without a compressor would be appreciated.
Old Sep 21, 2001 | 07:17 AM
BRIGBOY's Avatar
U need the compressors!!!!!!!!!!!!!!!!
Most definitley need them to remove the stock springs. However when you replace them with the H&R's, because they are approximately the size of the compressed stock springs, body weight will be sufficient enough to get the center bolt on and then just tighten it up.
This is what I did when I installed my eibach last Saturday. The istall is very fresh in my mind so hollar if you have more questions.
There is no way to get the stock springs off without compressors. When you loosen the centerbolt the spring will buckle and "jump", most likely causing serious injury.
Old Sep 21, 2001 | 07:51 AM
NickStam's Avatar
Re: U need the compressors!!!!!!!!!!!!!!!!
Use the spring compressor dammit . You can rent it for free! (just need to give a deposit).
Old Sep 21, 2001 | 11:33 AM
njmaxseltd's Avatar
Re: Re: U need the compressors!!!!!!!!!!!!!!!!
ok ok Spring compressor it is.
Old Sep 21, 2001 | 01:54 PM
Alex97se's Avatar
post some pics after the install!
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
pears
Sep 18, 2015 05:25 AM
Stagnet04
Sep 13, 2015 09:32 PM
Johnny9595
Sep 3, 2015 05:18 AM
