european springs such as apex, B&G suspension anyone with any thought info or pics
i want to lower my car and am having a tuff time deciding on springs i am hearing so many mixed veiws. i was wondering if anyone knew the reputation of these companys and could give any feedback. towards them.thanks,louis
Originally posted by Gotrice4
H&R's are European springs....specifically German...they have a good rep as being more comfortable than most springs...
Originally posted by loup1276
yes but iwas looking for something a bit lower i heard the intrax cause the rear end to sag so i guess they are out of the question..thanks for the reply
Yeah, I just installed apex springs 2 days ago and I was very happy with the drop and with the ride. I only changed the springs and kept the stock '99 SE struts and the ride feels almost identical to the stock setup but much lower.
I found that the rear looked a little lower than the front with the apex springs, but even with the stock setup the rear looked lower already.
I think the springs lower the max around 40mm or so. The ones I bought had been used for around 1 year so the drop was a little more since they settle after time.
I wish apex would lower the front a little more because when I have my sub box in and other junk in the trunk the rear will be dragging on the ground.
Originally posted by black019
where can i find more info on apex springs? about how much is the drop? if it sags in the back you can always cut the front ones a little even tho thats taboo I guess...
Yeah, your right, the springs lower the car the same front and back. It looks lower at the back on my car because I have a huge bandpass box in the trunk.
When I said they sagged I meant to say they settled a little bit. I am very happy with them so far.
Originally posted by 97GLES
if you look at the bottom of the car it should be even or just a tad higher in the rear with nothing in the trunk. the apex springs don't sag at all and if they do send them back. the front fender will look a little taller because of the cut of the fender well. the rear will always look better than the front. the drop on the apex are about 1.6" drop.
. i just don't like my tokico's
Finkle
Sep 27, 2015 09:53 PM
95Maxi
35
Sep 2, 2015 10:37 AM
