300z clutch
Old Sep 24, 2001 | 10:14 AM
99NosMax's Avatar
300z clutch
does anyone else have a 300z clutch installed in their max???
and if so, did you have any problems with the install? how long have you had it? any problems?
Old Sep 24, 2001 | 10:27 AM
Nealoc187's Avatar
SLOW
the 300Z has a different engine. I assume this means it has a different transmission, and a different clutch.
Old Sep 24, 2001 | 10:56 AM
99NosMax's Avatar
i read on maximadrive.com that you can use a 300z clutch in a maxima
i'm currently useing a 300z clutch, and was wondering if anyone else had it done and if there were any problems?
Old Sep 24, 2001 | 02:10 PM
MaxSE98's Avatar
ive heard from many sources that the pressure plate that is part of the 300zx kit is the strongest out there for its size- 255mm i think
-pete
Old Sep 25, 2001 | 08:57 AM
got rice?'s Avatar
-pete
The NA uses a 240mm, the TT uses a 250mm.
Old Sep 25, 2001 | 11:22 AM
Maxwell's Avatar
You're using the 300z clutch, but you want to know if it works?
I know how you can find out...
Old Sep 28, 2001 | 10:09 PM
99NosMax's Avatar
i wanna know if anyone has had any problems with it, is it something that will last...
Old Sep 6, 2002 | 08:03 AM
xraytedrick's Avatar
300z clutch
i've performed a search on the subject and have found little info
on maximadriver.com it's written that the 300z clutch is a cost effective alternative to a performance clutch.
i've found that the 300z non aspirated clutch is the same diameter as the maxima's but it is a different nissan part number. (some members of the org stated it's the same clutch).
also during my search i found that people who stated to have problems
may have used the turbo clutch instead hence leading to the problems.
i'd like to know if any 300z na clutch users are out there and what their experience has been.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
