Spring Install Pricing
Old Sep 25, 2001 | 02:52 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i did my own.....
i went and got quotes and was quoted anywhere from 250 - 600
200 is a good price
Vyrus's Avatar
Spring Installation Prices...
Most of my local performance shops run $200-$250, but once local shop I go to quoted me $135. I got them installed for free (I love connections), but remeber you will still have to pay $50+ for an alignment (you must go to a shop that does camber).
breaux124's Avatar
Re: Spring Install Pricing
Originally posted by slammed95
I just got new springs to drop my max 2". Now I need to get them installed and I need to know how much I should expect to pay. I asked my mechanic and he said $200. My friend said he got his coilovers installed on his accord for $60 and it would cost the same for me.
How much have you guys paid for installation of lowering springs?
I don't want to pay only $60 and have something done wrong.
Do it yourself.
But $200 seems like an average price. Call out to maxima owners in your area and see if anyone is willing to help.
Old Sep 25, 2001 | 02:54 PM
NickStam's Avatar
Re: Re: Spring Install Pricing
It's usually 2 hrs labor. So find the cheapest labor and go there if you are worried about price.
Old Sep 25, 2001 | 05:24 PM
NickStam's Avatar
spring compressors can be rented from your local auto parts store for free (deposit required).
Read this over and see if you can handle it.
http://www.performanceix.com/how-to/...print_koni.asp
Old Sep 25, 2001 | 05:40 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
and you get the deposit back so the rental ends up being free
Old Sep 25, 2001 | 06:58 PM
NickStam's Avatar
what part of my post didn't say it wasn't free?
Old Sep 26, 2001 | 12:46 AM
cobymoby's Avatar
WHAT!! $200!!! That's a total rip off. they will try to tell you that it will cost more because it's a Max.. it's more difficult.. bla, bla... but they are lying to you. It is the same as lowering a Civic or integra. You shouldn't pay more than $80-100 without an alignment. Even that's high.
Old Sep 26, 2001 | 05:51 AM
njmaxseltd's Avatar
Did mine last Saturday. The job is pretty easy, you need a good spring compressor and I highly recommend replacing the strut bearing while you have it apart.
Old Sep 26, 2001 | 06:38 AM
NickStam's Avatar
Also,
If a place doesn't really want to do it, they might charge you a bit more.
Old Sep 26, 2001 | 09:18 AM
MegaMax's Avatar
Done at a Shop for...
$175.00 that comes with a 4 wheel alignment too...
Let me know I’m in central NJ
Old Sep 26, 2001 | 09:33 AM
iansw's Avatar
A local racing shop in Seattle quoted me $140 to install both Struts and Springs....$200 is way too high for just springs.
I then went to the local Midas, and they wanted $600.00!!!
Midas are a bunch of sheisty bastar*s.
IanS
Old Sep 26, 2001 | 12:46 PM
fast97maxse's Avatar
Hey Nick
Nice set of instructions, thanks.
I have a set of H&Rs I think I'll try to install this weekend.
Two things though...
In jpg 5 it looks like you’re using a 12-pack as a jack stand. Is this recommended? Should they be cold?
Also, the thumbnail for jpg 13 duplicates the tn for jpg. 14…
I know, a small detail in an otherwise perfect how-to.
Thanks again
Old Sep 26, 2001 | 01:24 PM
NickStam's Avatar
Originally posted by fast97maxse
Hey Nick
Thanks again
Use anything you can find to support the rotor. We didn't have a good picture, so we used the same one .
Old Sep 26, 2001 | 01:25 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i missed it...i just saw you had deposit required
Old Sep 26, 2001 | 01:30 PM
I'm that guy from rfield.
You around this weekend?
Wanna help install some springs?
I'm not going to replace the struts yet
and seeing how you've already done it,
this shouldn't even take but a couple of hours...
Old Sep 26, 2001 | 01:41 PM
NickStam's Avatar
I'm home but i'm kinda handicapped......do you have any helpers?
Old Sep 26, 2001 | 02:20 PM
97GreenMax's Avatar
Actually, I went and got a price today. They told me it take about 4 hrs. Most shops charge about $55 an hour, so about $250.
Old Sep 26, 2001 | 06:15 PM
VQdriver's Avatar
i am desperate for help on installing my springs! i bought a used set of eibachs/tokicos and the guy that sold it to me told me i have the rear springs installed upside down! he said the word "eibach" must be legible on all the springs and not upside down..i called eibach and the tech guy said the same about the rear -that "eibach" must be legible from the wheel well. i just don't see how that will work. the springs seems like it won't fit that way! i'm probably wrong..but that would mean i need someone's help with spring compressors since i've never used them before. for the fronts, the progressive coils (tighter coils) must be pointed up. its just pretty frustrating. the rear end is slightly lower than the front and i get a noise eminating from the R rear shock. i don't want to drive it now that i know its mounted "upside down." if anyone can help me out with directions on spring compressors and which way the springs are supposed to be mounted, i'd appreciate it. i'm in the south jersey area if you feel like helping me reinstall my rears does anyone else have them installed upside down? haha
Old Sep 27, 2001 | 11:53 AM
VQdriver -
not sure about how all of the compressors work but the cheapest [and therefore most common variety] are basically a threaded rod with hooks on them. You open then up all the way, stick the hooks on each end of the spring and then tighten a nut. This moves the hooks closer together and compresses the spring. A power tool or a drill with a socket attachement helps a lot here. You need to use two compressors at a time on the spring - about 180degrees apart - and tighten them each a little at a time, alternating from one to the other. use common sense - and never point the ends of the spring towards your body. If you rent them, ask for a demonstration or instructions. If you buy them they should oughtta come with instructions. If you're even just a little handy you shouldn't have any problems. good luck
Old Sep 27, 2001 | 02:24 PM
MAXTOUT's Avatar
strut bearing
You can get strut berings at autozone for ~$25 a piece. I asked at my local autozone and they said they would have to order, so check in advance. Good luck on the install.
TED
dank4us
34
Jun 10, 2024 03:45 AM
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
95Maxi
35
Sep 2, 2015 10:37 AM
