hey hlh0501...trans question again...hehe
Old Sep 25, 2001 | 04:14 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
hey man, got another 5speed question to ask you
when you put in the pilot bushing, how did you pull that spacer type thing out? im at that point rite now and i couldnt get the pilot bushing in and then my friend's shop told me i need to remove the spacer first...thanks! also, did you change the speedo or used the orginal one? thanks
Old Sep 25, 2001 | 04:17 PM
Jeff92se's Avatar
I'm needing a caw
Spacer from the auto? Well if you have some room, you can either try to crack it and remove it w/ a chisel or try to get a hook behind it and pull it out w/ a slide hammer type thingie(like a dent puller) If the spacer is thick enough, you could try to thread a bolt on there and then pull it out from the head of the bolt but I would be carefull with that one.
Old Sep 25, 2001 | 04:22 PM
Turbo95Max's Avatar
thanks Jeff
they told me to juss use the special tool for pulling out pilot bushing/bearings. I tried with a screwdriver and it didnt work. SOmeone stole my chisels so cant try that.
Old Sep 25, 2001 | 04:25 PM
Jeff92se's Avatar
I'm needing a caw
Yeah just try to rent the tool. As for the chisels, I bet mr. maxima tt did that.
Originally posted by Turbo95Max
thanks Jeff
Old Sep 25, 2001 | 05:23 PM
Daniel B. Martin's Avatar
Originally posted by Jeff92se
Yeah just try to rent the tool. ...
http://www.harborfreight.com/cpi/cta...temnumber=4876
Maxboy23
Sep 4, 2015 06:04 PM
nbstriker10
Sep 4, 2015 04:26 PM
DrVee
Sep 4, 2015 12:18 PM
mikebla
Sep 3, 2015 05:37 PM
sdotcarter
Sep 2, 2015 09:53 PM
