any way to disable passenger airbag?
i drive around with my golden retriever in the front seat sometimes, and it occured to me if i got in an accident, he would get a face full of airbag that woudl do more harm than good cuz he's not belted in. is it possible to disable that thing?
mike
mike
Airbags do more harm than good anyways. You would need to disable both airbags, because they are on the same circuit. Then you have to get resistors to fill in the disabled parts so that you don't have the airbag warning light flashing in your dash all the time.
Re: any way to disable passenger airbag?
mike
mike
mike
mike
So here is the best way to disable your air bag system.. (you have to do both)
Take the negative cable from the battery..
take the center consul out of the car.. disconnect that box you see in the middle w/ the yellow (on 96 it is) cable. (just remove the cable.. ) put everything back together.. When it is time to sell your car reconnect the box following the same procedure.. Your light won't be on because it has been powerless the entire time it was disconnected...
If you wreck your car while it is disconnected.. You may need a new box.. (not quite sure how it works) but if you do and you hook it all back up and your light is on you need a box...
Just a warning. You will need to place a resistor in the terminals of the plug to get the dash light to go off. To find the value you'll need, get a variable resistor and hook it up. DO NOT use a multimeter to find the Ohm reading of the airbag...it will go off in your face. The multimeter applies current and measures voltage drop to get resistance...
Well, you need to unplug the airbags BEFORE you start prodding around in the wiring.
much harder that the back of your seat
