Cattman Y-Pipe Problems??
I have a 97 Maxima SE and am interested in the Cattman Y-pipe, but I have heard that the Y-pipe for the 4th Gen's by Cattman have a few problems. Two things that I heard was that the unit doesn't have a welded on bracket, so once you screw in the tops of the "Y" and the cat to tye pipe, there's nothing else to hold up the pipe, and this causes lateral jiggling and the pipe will hit the undercarriage of the car. Also, I read that the 0-2 sensor plugs are really poorly placed and they will hit other parts of the car from the jiggling of the Y-pipe. Can anybody confirm or deny this info at all??? I'm itching to buy a Y-pipe, and I finally have the $$$!
Re: Cattman Y-Pipe Problems??
mine is great...no clunking or abnormal sounds whatsoever. The O2 sensor holes are placed better in my opinion than the stock pipe..they are VERY easy to get to. There doesn't need to be a braket becuase the cattman y is 8lbs vs. the 23 lb. stock pipe. Anyone who is experiencing clunking probably has an engine mount or 2 that is shot allowing A LOT of engine and exhaust system movement and they blame it on the y-pipe.
Yeah I he likes it now that its in, but he was pretty stressed over it. Its supposed to be better than the Stillen Y pipe. Have you looked into the Budget? Or is this the budget? I'm going to go with Catman.
No, I haven't looked into the budget, I want to make sure I get a high quality piece of equipment that will last and that is not too loud. I know the Cattman is supposed to be made of high quality metal, I just want to make sure I won't have any periferal problems such as the knocking into the undercarriage or the o2 sensors.
IMO a pipe is a pipe...
..is a pipe is a pipe. Stainless steel is stainless steel. If the diameter is the same, then the pipe is extremely similar to any pipe in the same diameter.
I'm also making myself feel better about buyin a budget Y today. Hopefully when I install it I will really feel good. And you all will know about it.
Re: Re: Cattman Y-Pipe Problems??
Originally posted by yourmove
I went Stillen. It fits like a glove! Sounds great!
my friend has intake y pipe and apexi cat back.
my car has intake only, and in just roar they are about the same. but his has tone with it... sounds as loud just deeper. so if you can live with your intake, you'll be able to live with the rest. how often do you drive with no music play'n even low. his car is just as quiet on cruis'n speeds as mine. But it lets you know when he opens it up...
sounds like your sold on the idea then... tell me.. how hard was it to do your pulleys? what kind of difference did it make?
Re: Re: Re: Cattman Y-Pipe Problems??
So you like the sound of the Stillen, huh? Do you have an otherwise stock exhaust? Just curious...I don't mind some noise, I just don't want it obnoxiously loud or anything...I don't think I could handle it all the time.
Kirk
no offense I was asking about the pulleys,
Kirk I'm a student... I'm looking for cheap "aurora colorado style" thrills. he he he. some colfax ave cheap thrills... j/k
but yeah how much does it cost to do the pulleys?
Kirk
P.S. How'd you know about Colfax?
[i]but yeah how much does it cost to do the pulleys? [/B]
Hey Aaron, your local (washington) right? I have the Cattman SS y-pipe, and I love it. I'll be going up to seattle soon again, we should hook up and you can drive my car to see the differences.
Casey
Casey
Re: Re: Re: Re: Cattman Y-Pipe Problems??
I had the stilen b& muffler. They sound nice and very harmonic with a pop chgr. The added Y-pipe and rt cat is cosiderably louder. I don't think the rt adds noise.
Kirk
Re: Re: Re: Re: Re: Cattman Y-Pipe Problems??
Originally posted by 1/3There2/3ToGo
The RT cat does increase volume. It reduces the restriction on the exhaust = more noise.
Kirk
Kirk
Re: Re: Re: Re: Re: Re: Cattman Y-Pipe Problems??
Originally posted by BriGuyMax
Actually the R/T cat has been know to quiet down the max's exhaust system....especially the drone with most cat-backs.
Kirk
I've had the warpspeed original. Then I replaced the flex section with a lined one. Now I have the Cattman.
I had a slight issue with fitament, but it was a few pipes that came out of the specific batch. I fixed it myself, but Brian Catts was very willing to send me a new Y-pipe.
I'd recommend the Cattman if you can afford it.
I'm not to sure about the Budget though, since it's not Mandrel bent. This will reduce the air flow, which could result in less hp than the mandrel bent Y-pipes. Also, Cattman uses a lined flex section to reduce noise.
(cough) search function (cough)
(cough) www.budgetexhaust.com (cough)
Originally posted by Yomie
Where can you get these budget pipes from?
Kirk
Kirk
Just cause air flows faster doesn't mean it's noisier.
Actually if you get the courtesy B-pipe, it increases air flow but does not increase the noise.
Maybe in your specific case the RT cat added additional noise, but you can't say that's true for all cases.
My RT cat had no effect on the sound of my exhaust.
Kirk
KabirUTA13
19
Oct 17, 2015 02:15 AM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
