Spark Plugs DIY?
Old Oct 2, 2001 | 09:20 PM
hbsprite's Avatar
Spark Plugs DIY?
Has anyone installed their own spark plugs. I am an amateur with basic mechanical knowledge. Should I attempt it or leave it to the professionals?
Old Oct 2, 2001 | 09:38 PM
AGnismo's Avatar
Yes, you can do this own your own. All you need to do is remove the valve cover (front spark plugs) and then unscrew the coil (one cover each spark plug). Make sure you have plenty of extensions for the spark plug bolt.
Old Oct 2, 2001 | 09:42 PM
NickStam's Avatar
get a manial too. they help out a great deal.
Old Oct 2, 2001 | 10:15 PM
Sonic's Avatar
One problem with that, you are going to need a Torx screwdriver to get the valve cover off, but they usually come with a tool kit anyways.
Old Oct 2, 2001 | 11:17 PM
guido_sst's Avatar
No, he'll need a 4mm Allen wrench, not all that hard to come up with.
Old Oct 2, 2001 | 11:18 PM
guido_sst's Avatar
I find a 3/8" drive 10" extension to be just about perfect for getting at them.
Old Oct 3, 2001 | 12:50 AM
Mr. Nismo's Avatar
Don't forget to torque them to specifications!!
Old Oct 3, 2001 | 02:21 AM
maximasrule's Avatar
Re: Spark Plugs DIY?
or you can do what i did.. just do it and when your done it always works...... maybe its just cause im so good though?!!!
Old Oct 3, 2001 | 09:12 AM
Ravq's Avatar
Spark Plug procedure
Here ya go:
http://integra.vtec.net/geeser/megamax/60k_service.html
Old Oct 3, 2001 | 10:13 AM
Axra's Avatar
Should use anti-sieze on the plugs too.
Old Oct 3, 2001 | 10:17 AM
Daniel B. Martin's Avatar
Read the Sticky
Please read the Sticky Thread Important: 4th Gen Maxima Maintenance Items. The second post in that thread provides detailed instructions and pointers to other information sources.
Old Oct 3, 2001 | 10:19 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
http://forums.maxima.org/showthread....threadid=45742
Old Oct 3, 2001 | 10:24 AM
Sonic's Avatar
Last time i didn't and didn't have any problems taking them out. Good idea though.
Old Oct 3, 2001 | 10:26 AM
bill99gxe's Avatar
On the VG30E, it's definitely necessary.......and on ANY American motor.
Old Oct 3, 2001 | 10:31 AM
Sonic's Avatar
Aluminum owns jOO!
Old Oct 3, 2001 | 11:04 AM
NYCe MaXiMa's Avatar
also..
make sure the gap is correct and don't over tighten them.. Basically, read the sticky and the directions... get a torque wrench too, it's handy in many things
Old Oct 3, 2001 | 11:36 AM
bill99gxe's Avatar
Re: also..
Exactly. Another wasted thread.
Old Oct 3, 2001 | 11:37 AM
1Phat Max's Avatar
do i have to get torque wrech for doing this or can i just tighten them with basic commen sense that not to tighted that much and also not to leave it loose? thanx
Old Oct 3, 2001 | 11:47 AM
Re: Re: also..
pretty sad huh?
During the past year at least 90% of all possible "general" questions have been asked before.
Old Oct 3, 2001 | 11:49 AM
You "can" tighten them with basic common sense. My dad never used a torque wrench in his life for anything, always tightened it just about right, you need to have a feel for it. However, it is reccomended, and if you'd like to do the job right and have a clear conscience about it, you should probably invest in a torque wrench, besides the thing is cheap and it is very useful in many, many other tasks.
Old Oct 3, 2001 | 07:52 PM
97GreenMax's Avatar
It is very easy man. If I can do it, you can do it.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
