Anyone have a problem with cracking fog-light lenses?
Old Oct 30, 2000 | 07:32 PM
OzMaToz
Has anyone had a problem with the lenses cracking from the heat from higher wattage bulbs? I was think of going with the Hella yellow 85w H3's, but I am worried about cracking the lenses if something cold hits the glass. I live in the northeast so I drive through crappy weather so better fogs would be nice, but I would hate to crack them if some cold snow or slush splashed on them. Any suggestions?
Old Oct 30, 2000 | 07:35 PM
Shingles's Avatar
The missing moderator
If you are worried and don't wnat to deal with it, don't do it. Last winter, I recall many a posts about this, especially from people with high wattage bulbs.
-Shing
Old Oct 31, 2000 | 05:14 AM
Che's Avatar
Che
yep,
my passenger fog cracked last winter....as a matter of fact, it's still cracked.
Old Oct 31, 2000 | 05:29 AM
Max96's Avatar
I have the 85w Yellow Stars on my '96. They are on all the time. No problems here........
Old Oct 31, 2000 | 06:39 AM
max95q's Avatar
my fog light lense is cracked also
kinda right across the middle of the lense from one side to the other, I have catz and I didnt put any special high wattage bulbs in there. but I dont worry about it as long as they still work and show the road its all good, plus its barely noticable since the lens is blue.
Old Oct 31, 2000 | 08:09 AM
Bernie Lomax's Avatar
SO broken....
I put 100W bulbs in there. WHOOPS!! Not a smart move. Cracked both of them. Driver's I replaced, passenger is still cracked, but doesn't leak so I am leaving it. Get some blue H3's and keep it at 55W. You will not see a noticeable difference in upping the wattage, and it's expensive to get new lamps unless you find a nice Maxima.org person with an extra fog in his garage. (Thanks Rich!)
Old Oct 31, 2000 | 09:46 AM
OzMaToz
THANKS!
Thanks for the info/advice. Seeing as how I barely had enough money for the car, I wont go and do anything that could cost me more! Thanks!
Old Oct 31, 2000 | 11:43 AM
Albertt's Avatar
Shing: I have another idea >>
-Shing
You've heard of Candy apple red paint...it's like a clear red color...maybe they make a clear yellow paint...take this and spray the inside reflector or the inside of the foglamp lens yellow...so that a regular white bulb will give that deep yellow color. One just has to make sure to keep the coating thin so as not to kill too much of the brightness.
I installed the 55W Hella Yellowstars in H3. They were not as yellow as I had hoped.
Old Oct 31, 2000 | 01:36 PM
Matt_P
I don't think pushing it to 70 watts would be that
greedy. Try 70 watt yellow bulbs.
Matt P.
Old Oct 31, 2000 | 03:52 PM
stjohnr's Avatar
85w is way too much for th lens. I had a
crack at one time using 85w
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
