Stillen Cross Drilled Rotors From EatRiceZone
I am considering purchasing the Stillen Cross Drilled Rotors and Pads from EatRiceZone.com.
Anyone that has them on their cars, I would appreciate your input.
Or any other recommendations on other brake setups?
Thanks...
Thanks...
Originally posted by AznWontonboy
if you want to buy cross drilled rotors, dont buy it from stillen or anywhere else. i havent heard of anything but good things about Phuong. (i dont know him) i believe hes GotRice? on this board.
Kirk
Re: Stillen Cross Drilled Rotors From EatRiceZone
Thanks...
Thanks...
Re: Re: Stillen Cross Drilled Rotors From EatRiceZone
Originally posted by deezo
The rotors are great but I am getting squeal from the pads. I would try looking into another type of pad though.
Originally posted by mrb23
Are you guys just using stock calipers with these rotors? Is there a lot of improvement with these rotos and stock calipers? I think I may need to upgrade my brake system and SOON too. thanks
Do you have the metal master pads? Do all stillen cross drilled rotors and metal masters combination squeal?
i've got the stillen slotted rotors and the stillen metal matrix pads, i dont get any squeal... occasionally, when i press the brake, at a slow speed, i can hear the pads rubbing against the rotors, kinda like a groan/grinding sound. that also when brakes havent been used overnight, but that is probably from the light rust that forms on the rotor.
dfwmax
dfwmax
Re: Re: Re: Stillen Cross Drilled Rotors From EatRiceZone
That's one thing that I can't stand-is squealing from my brakes. I had this problem with my bmw. They deglazed it several times bf changing the pads and the squealing stopped. It was annoying especially on hot summer days.
Re: Re: Re: Re: Re: Stillen Cross Drilled Rotors From EatRiceZone
Originally posted by got rice?
bling bling.
bling bling.
Re: Re: Re: Re: Re: Re: Stillen Cross Drilled Rotors From EatRiceZone
Any auto parts store should have it or should I just get it from the dealer?
Re: Re: Re: Re: Re: Re: Re: Stillen Cross Drilled Rotors From EatRiceZone
Pepboys carries the CRC brand so they *should* have it. The CRC brake grease is a pinkish/reddish color.
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
hey Maximum Pursuit your car sounds nice..
