daniel b martin... i have another question
sorry if i'm becoming a pain. i'm trying to educate myself as fast and correct as i can, but i'm new to the whole idea of fixing my own car. i truly appreciate all of you for your patience with me.
now that i've fixed my mafs, the only problem is that my idle is very, very low ... any lower and the car will stall. i'm looking at my haynes manual all day & doing my best, but i hit a snag. i reset the idle speed via the adjustment screw, and now she's back to 700ish rpms... running great. my question is this; is it possible that by cleaning the throttle body (for the first time in 112,000 miles) and replacing the mafs, that i needed an idle adjustment? i did the check where you let it idle and throw the a/c to max - passed that test no problem. i get no codes now either. i'd really appreciate your opinion. i did a search here on "idle" and noticed that you had told someone else that adjutsing the idle may only mask other problems. i get no code, so i'm hoping it's just the recent change in my mafs and that "path". as always, thanks.
maury
maury
Re: daniel b martin... i have another question
maury
maury
thanks guys. i did the "haynes" check on the iacv and it passed. i'm going to try and look for leaks, but so far i'm not sure how...visually all hoses look ok. i'll keep at it, and if either of you guys have another idea, it's definitely appreciated. you guys are really great to be so helpful. still no codes so far.
thanks
thanks
Originally posted by medicsonic
Idle Air Control Valve. Do a search for that inseatd.
Re: Re: daniel b martin... i have another question
Originally posted by emax95
Your best bet whould be to check for air leaks after your MAFS.
maury
maury
"Idle Air Control Valve (IACV) -- Auxiliary Air Control (AAC) Valve
This system automatically controls engine idle speed to a specified level.
Idle speed is controlled through fine adjustment of the amount of air which
bypasses the throttle valve via the IACV-AAC valve. The IACV-AAC valve
changes the opening of the air bypass passage to control the amount of
auxiliary air. ... "
The correct idle speed is...
- 700 +/- 50 (automatic transmission, in Neutral)
- 625 +/- 50 (5-speed)
Here's the factory service manual component inspection procedure for the IACV-AAC.
1) Make this test with the ignition key OFF. Disconnect the IACV-AAC valve harness connector.
2) Looking into the valve connector with the latch at the top, you will see two rows with three terminal positions in each. They are numbered 1-3 (top row, right to left) and 4-6 (bottom row, right to left). Check resistance between the following terminals.
2 and 1.
2 and 3.
5 and 4.
5 and 6.
At a temperature of 68 F, the reading for all measurements should be approximately 30 ohms.
3) Reconnect the IACV-AAC valve harness connector.
4) Remove the idle air adjusting unit assembly (IACV-AAC valve is built-in) from engine. The IACV-AAC valve harness connector should remain connected.
5) Turn ignition switch ON and OFF, and verify that the IACV-AAC valve shaft smoothly moves forward and backward. If NG, replace the IACV-AAC valve.
There are other engine parts which play a role in maintaining the right idle
speed, but the IACV-AAC is the first thing to look at. Good luck!
thanks daniel. yeah, i just checked the resistance across the terminals and it passed... i haven't yet done the other test yet. i'll go and try that right now and post my results in a few minutes. also, is there any type of cleaner or "engine flush" i should do at this mileage (112k)... like something on the shelf at autozone, or a dealer service? thank you
maury
maury
... my question is this; is it possible that by cleaning the throttle body (for the first time in 112,000 miles) and replacing the mafs, that i needed an idle adjustment? ...
... i did the check where you let it idle and throw the a/c to max - passed that test no problem. ...
... i get no codes now either.
... and noticed that you had told someone else that adjutsing the idle may only mask other problems. ...
thanks daniel. i apologize for the delay... it's been a long day
yes, when i cleaned the throttle body it was still connected to the intake. since your last post, i took out the iacv housing & checked the black shaft for movement - it moved. i took the whole thing apart and i did find black gunk in there (not tons of it, but it was not clean.) so i cleaned in there with some throttle body spray, reassembled everything & took a test drive.
now it felt as though my idle was slightly too high, so i put the car in self-diagnostic mode & reset the idle screw to where it was originally. right away i got a code 0806 - fuel lean or rich in left bank. i thought "give me a break!" i cleared the code & took 2 test drives since and it feels like we're back to normal.
in summary, i cleaned the tb, changed the mafs, increased the idle speed via screw, cleaned the iacv, and lastly returned the idle to where it should be. thank you all for the help and with any luck, we're done here!
sorry for the long post, but i wanted you to have all the info.
good day,
maury
good day,
maury
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
