tires size...
Old Oct 7, 2001 | 12:47 AM
Ruckus's Avatar
tires size...
what's up guys (and girls). i'm about to bid on some tires on e-bay. i'm not sure if these tires will work though. i got bigger rims so i'm itching to put them on. the rim size is 16x7, +50mm offset, momo corse. the tires i am looking at are:
V Rated Bridgestone Potenza's size 205 60 16 RE92
Bridgestone Potenza RE92 205/55 R16 V-rated
oh, i just realized they are basically the same thing, but hey, will they work? i'm not too familiar about those sizes, but my friends and the dude i bought the rims from suggested a few sizes, and these are right in the middle.
Old Oct 7, 2001 | 07:10 AM
JUDE's Avatar
Definetly don't go for the one with the 60 height. It won't look good on your car. Go with the one with 55 or maybe even 50. Also, I think the 205 is too small. Go with 225 or at least 215
Old Oct 7, 2001 | 08:56 AM
Ruckus's Avatar
cool...
thanks a lot, i'll check out some other places then. also, it'd be great if someone could explain how these tire sizes work. i know the last number goes with what rim size they will fit on, but i wasn't too sure about the first two numbers. any info would be great, thanks a lot.
Old Oct 7, 2001 | 09:24 AM
Maximum Pursuit's Avatar
Tire Size
Example: 225/50R16 89V
225=the width of tire in mm, measured from sidewall to sidewall
50=hieght of the sidewall
R16= raduis of the tire in inches
89= represents tire's load index
V= Speed rating the maximum speed for which the tire is rated.
I would go with 225/50ZR16 if you don't mind the wheel gap. Going with a +50 offset might rub on your wheel well.
Old Oct 7, 2001 | 10:20 AM
Xtreme5053's Avatar
Re: Tire Size
also, another thing to keep in mind is keeping the overall circumference as close to stock as you can Tire size calculator also, tirerack.com has many help sections to educate you on the ins and outs of tires.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
