MAF Problems
MAF Problems
I think I might have a damaged MAF. Here are the problems:
1. Sometimes when I start the car in the morning the car starts up to around 1000 RPM and then drops down to about 400, sounds like its about to die and recovers. Then its fine.
2. I am getting horrible gas mileage. This last tank was all stop and go driving and I do drive fast at times but I don't floor it away from every stop sign. I got 16 MPG. The tank before that was half interstate driving going about 60-75 and the rest city. I got 20 MPG. Do these sound normal?
Well I got a Chiltons manual and just tested the MAF. My Voltometer was not the digital kind shown in the manual but one with a needle that moves like a speedometer. I warmed the car up and then turned the engine off and took a reading. I needle moved about a 1 mm. It wasn't even at the zero line. Then I started the car and got a little less than 1 volt at idle. I revved the engine and it had a linear increase but I don't know what it was at 4000 because I was under the hood. Soooo, do I have a faulty MAF? If so, will Nissan cover it under the extended warranty plan? I am schedule to have the car inspected by them on the 27th with their free inspection month so I might have them test it then. BTW, its a 97 GLE with 50k on it. Thanks.
Re: MAF Problems
I guess I will just have to wait. Is there a way to test the O2 sensors? The reason I thought it might be my MAF is that I put an intake on and then changed my fuel filter. I thought I may have damaged it during one of those. How does that gas mileage sound? If either an O2 sensor or the MAF was not functioning properly, wouldn't I get a check engine light?
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
