Random Tech. cat + Y-pipe
Old Oct 12, 2001 | 05:24 PM
sleeperGXE's Avatar
I already have a $tillen y-pipe on my car and I wanted a little extra boost in power; what (if any) difference would a new catalytic converter from Random Tech make? Custommaxima claims a 14 hp increase....
Old Oct 12, 2001 | 05:28 PM
Jon91SE's Avatar
Pusssseeeehhhh
Re: Random Tech. cat + Y-pipe
Slight gains in the top end .............
Old Oct 12, 2001 | 05:55 PM
BrianV's Avatar
I felt nothing, but it made the car run smoother and it doesn't drone as bad.
Old Oct 12, 2001 | 06:10 PM
sleeperGXE's Avatar
So is it worth the $175 bucks? There's not a whole lot else I can do performance-wise for that price, right?
Old Oct 12, 2001 | 06:11 PM
Jon91SE's Avatar
Pusssseeeehhhh
UDP.......
Old Oct 12, 2001 | 06:52 PM
sleeperGXE's Avatar
Originally posted by maxse91
UDP.......
yeah i thought about a pulley, but that has no real performance gain either.
enticiveblkmax's Avatar
hell no. its only worth it if your stock cat is old and not functioning properly. mine leaks and i think i have heard of others leaking as well.
Old Oct 12, 2001 | 06:59 PM
Tai Mai Shu's Avatar
B-pipe... CAI, will yeild high HP, with a Y-pipe, if you don't aready have one.
Old Oct 12, 2001 | 07:35 PM
seouljah's Avatar
yo brian you're gonna go for the 300?
Old Oct 12, 2001 | 09:12 PM
1/3There2/3ToGo's Avatar
My cat did reduce the drone too...dont really remember any astounding performance gains.
Kirk
Old Oct 12, 2001 | 09:59 PM
Jon91SE's Avatar
Pusssseeeehhhh
Well thats to be debated......
Old Oct 13, 2001 | 09:38 AM
ybelm620
If you don't already have one, get a custom 2.5 inch cat-back with no resonator, along with your high flow cat. Also what kind of muffler do you have, if you have a stock muffler i would recommend an Apexi N1 or HKS Hyper muffler.
Old Oct 13, 2001 | 09:51 AM
NYCe MaXiMa's Avatar
there is no way
a CAT can give ya 14 hp!! The CAI probably doesn't give ya that much... best bolt on bang for the buck = Y-pipe which gives around 15 hp +/-
Old Oct 13, 2001 | 10:55 AM
sleeperGXE's Avatar
Re: there is no way
Well first I have to fix the leak in my Y-pipe, which will probably improve performance more than a new cat anyway.
Old Oct 13, 2001 | 04:08 PM
yourmove's Avatar
I don't know about auto's but my UDP on a 5-spd. was a very nice gain!
Old Oct 13, 2001 | 11:41 PM
Fish254's Avatar
what about if you run a straght pipe with not cat?
Old Oct 14, 2001 | 07:21 AM
SLC I30t's Avatar
Dont you lose a lot of back pressure and torque with out running an exhaust? If so I would imagine thats why you don't run with out them
Old Oct 14, 2001 | 08:59 AM
You will lose backpreasure. This will make you lose torque. It is not bad for the car, ist just that there are no benefits, you only lose power. You might gain slightly on top end rpms, but I dont think it will be enough to compensate for the lost torque.
Kirk
Old Oct 14, 2001 | 09:21 AM
Jon91SE's Avatar
Pusssseeeehhhh
Kirk
How is your dual setup holding backpressure?
Old Oct 14, 2001 | 09:26 AM
Its split at the muffler
Kirk
Old Oct 14, 2001 | 03:38 PM
SLC I30t's Avatar
so it's just a dual tip exhaust, essentially?
Old Oct 14, 2001 | 06:38 PM
No
Old Oct 14, 2001 | 06:47 PM
bigpimpin
yea ok
Well if its from the muffler out... then you can call them what you want but they are just tips, if they are 5 inches in depth or if they are 6 feet... just tip
Old Oct 14, 2001 | 06:55 PM
In this months Sports Compact Car, they say that, its just an old hot rod saying, 1-6 Lb, of back pressure, its good, and its very hard to get that, so no, you realy can't go wrong with min. back pressure. How ever the idea is to keep the pressure, it a ythem, once you lose that, you lose Touqe.
Old Oct 14, 2001 | 07:07 PM
Re: yea ok
I have a Camero muffler. Does that mean that since my set up is like a camero's that cameros only have dual tips? I have the same set up only modified to fit a maxima. It is dual exhaust. It is not FULL dual exhaust, but none the less, it is dual. The muffler, like on cameros, has one inlet and 2 outlets. You can call it whatever you want, but it is DUAL EXHAUST.
Kirk
Old Oct 14, 2001 | 08:56 PM
SLC I30t's Avatar
I think you can call it a Soup sandwhich if you want too... but I have to kind of agree the the big Pimp . Just because with a name like that, he can only know what he's talking about.
But I had something similar on my old legend... one pipe in 2 pipes out, but I think it was refered to as dual port exhaust...? when I think of a dual exhaust... I'm thinking...Corvette...I'm thinking...mustang SVT... you know Dual meaning 2 and all...I guess I'm lookin for 2 mufflers....
Old Oct 15, 2001 | 03:45 AM
Dahnryman's Avatar
cat
the cat actually only gains you 1+ hp...no noticible difference...the reason his site says 14 if you read closely its with the rndm tech cat back also....that gives the 14+ hp....as for udp...it does not gain hp...it frees it up about a 14 hp gain at the wheels..not bad for one pully...you would feel a night and day diffence between the too...like everyone says though....the y pipe is the best mod for the buck..... hpe that helps some...
good luck
Old Oct 15, 2001 | 07:51 AM
breaux124's Avatar
Depends on your setup.
If you have NOS, Turbo, or S/C a straight pipe can help alot. With forced induction, a free flowing exhaust is very advantageous.
I've seen a Mitsu Eclipse Turbo that gained about 15 rwhp from a straight pipe.
With a N/A Maxima, I'm not sure it a sraight pipe would do much.
Quickywd01
Sep 21, 2016 09:36 PM
maxinout93
Oct 31, 2015 02:04 AM
REDinLV
Sep 28, 2015 12:31 AM
